Wave shield code, consecutive and non-consecutive sounds
Re: Wave shield code, consecutive and non-consecutive sounds
by toby on Thu Nov 15, 2012 1:03 pm
adafruit_support
Oddly when I changed the code to "justpressed[0] and justpressed[1]", button1 (the toggle switch) now plays nothing and button2 (the momentary button) now plays the sound I wanted on button1. :(
I'm kind of hitting a wall where I'm starting to wonder "Did I just bite off more than I can chew?". This circuit is for a sculpture that's 100% built but lacking this crucial electronics component (also did I mention I had a deadline.... :shock: ) Needless to say I'm really freaking stressed out about getting this up and running.
I'm going to monkey around with this a little more today when I get a chance. I really appreciate the fact there are a couple people out there in the Internet tubes willing to help a none coder struggle through this. I'll see what I can accomplish today though and try not hassling you all too much.
Also on a side note I think I changed the code correctly to state my switches are being pulled low with 10k resistors then go high (5v) when pressed. It just occurred to me that this may be screwing something up as well if I incorrectly did that code wise.
xl97
"this is 100% fixable"
That's what I needed to hear right now. I can back up off the ledge now. :wink:
//do not kill self
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
int lastPlayed = 0;
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the filesystem on the card
FatReader f;      // This holds the information for the file we're play
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
#define DEBOUNCE 5  // button debouncer
// here is where we define the buttons that we'll use. button "1" is the first, button "6" is the 6th, etc
byte buttons[] = {7, 8};
// This handy macro lets us determine how big the array up above is, by checking the size
#define NUMBUTTONS sizeof(buttons)
// we will track if a button is just pressed, just released, or 'pressed' (the current state
volatile byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
  extern int  __bss_end;
  extern int  *__brkval;
  int free_memory;
  if((int)__brkval == 0) {
    free_memory = ((int)&free_memory) - ((int)&__bss_end);
  else {
    free_memory = ((int)&free_memory) - ((int)__brkval);
  return free_memory;
void sdErrorCheck(void)
  if (!card.errorCode()) return;
  putstring("\n\rSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  putstring(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
  byte i;
  // set up serial port
  Serial.begin(9600);
  putstring_nl("WaveHC with ");
  Serial.print(NUMBUTTONS, DEC);
  putstring_nl("buttons");
  putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
  Serial.println(freeRam());      // if this is under 150 bytes it may spell trouble!
  // Set the output pins for the DAC control. This pins are defined in the library
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  // Make input & enable pull-up resistors on switch pins
  for (i=0; i< NUMBUTTONS; i++) {
    pinMode(buttons[i], INPUT);
    digitalWrite(buttons[i], LOW);
  //  if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    putstring_nl("Card init. failed!");  // Something went wrong, lets print out why
    sdErrorCheck();
    while(1);                            // then 'halt' - do nothing!
  // enable optimize read - some cards may timeout. Disable if you're having problems
  card.partialBlockRead(true);
// Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {     // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                             // we found one, lets bail
  if (part == 5) {                       // if we ended up not finding one  :(
    putstring_nl("No valid FAT partition!");
    sdErrorCheck();      // Something went wrong, lets print out why
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(),DEC);     // FAT16 or FAT32?
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    putstring_nl("Can't open root dir!"); // Something went wrong,
  // Whew! We got past the tough parts.
  putstring_nl("Ready!");
  TCCR2A = 0;
  TCCR2B = 1<<CS22 | 1<<CS21 | 1<<CS20;
  //Timer2 Overflow Interrupt Enable
  TIMSK2 |= 1<<TOIE2;
SIGNAL(TIMER2_OVF_vect) {
  check_switches();
void check_switches()
  static byte previousstate[NUMBUTTONS];
  static byte currentstate[NUMBUTTONS];
  byte index;
  for (index = 0; index < NUMBUTTONS; index++) {
    currentstate[index] = digitalRead(buttons[index]);   // read the button
    Serial.print(index, DEC);
    Serial.print(": cstate=");
    Serial.print(currentstate[index], DEC);
    Serial.print(", pstate=");
    Serial.print(previousstate[index], DEC);
    Serial.print(", press=");
    if (currentstate[index] == previousstate[index]) {
      if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
          // just pressed
          justpressed[index] = 1;
      else if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
          // just released
          justreleased[index] = 1;
      pressed[index] = !currentstate[index];
    //Serial.println(pressed[index], DEC);
    previousstate[index] = currentstate[index];   // keep a running tally of the buttons
  byte i;
  if (justpressed[0]) {
      justpressed[0] = 0;
      playcomplete("CHEER.WAV");
     (justpressed[1]);
      justpressed[1] = 0;
switch (lastPlayed)
  case 1:
    playcomplete("ONE.WAV");
    lastPlayed = 1;
    break;
  case 2:
    playcomplete("TWO.WAV");
    lastPlayed = 2;
    break;
  case 3:
    playcomplete("THREE.WAV");
    lastPlayed = 3;
    break;
  case 4:
    playcomplete("FOUR.WAV");
    lastPlayed = 4;
    break;
// Plays a full file from beginning to end with no pause.
void playcomplete(char *name) {
  // call our helper to find and play this name
  playfile(name);
  while (wave.isplaying) {
  // do nothing while its playing
  // now its done playing
void playfile(char *name) {
  // see if the wave object is currently doing something
  if (wave.isplaying) {// already playing something, so stop it!
    wave.stop(); // stop it
  // look in the root directory and open the file
  if (!f.open(root, name)) {
    putstring("Couldn't open file "); Serial.print(name); return;
  // OK read the file and turn it into a wave object
  if (!wave.create(f)) {
    putstring_nl("Not a valid WAV"); return;
  // ok time to play! start playback
  wave.play();
toby
by xl97 on Thu Nov 15, 2012 1:11 pm
Hi-
first lets re-group and check our base..
1.) do you PHYSICALLY have your switches on pins: 7 & 8 (like the code states)
your first switch/button (which is buttons[0]) is the switch you have connected to PIN 7 on the Arduino.
your second switch/button (which is buttons[1]) is the switch you have connected to PIN 8 on the Arduino.
is this correct?
Also.. what is it you are trying to do even? Explain (not in code) the effect/results you are trying to achieve..
Press a button play a sound... press another button, play a different sound?
if a sound is currently playing when you press a button.. you want the current sound to stop and the new sound to play..is this correct?
if your around for a bit.. (not lagging between posts).. we'll get this fixed before I go to lunch
-xl
xl97
by toby on Thu Nov 15, 2012 1:14 pm
Also I forgot to mention.
For some reason when I use xl97's suggestion (see code below) it works okay except for the random 4-5 second delay after pushing button2. Unfortunately I can't have a random delay there. The odd thing is code has justpressed[2] in it! I know it should not though, it should just be justpressed[0] and justpressed[1] seeing as there are only two buttons.
Ohhh the confusion ......
#include "WaveHC.h"
char filename[10]; // leave enough room here.
int button2Counter = 0;
int freeRam(void)
  int free_memory;
  else {
  return free_memory;
  putstring(", ");
  while(1);
  byte i;
  Serial.begin(9600);
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
    sdErrorCheck();
  uint8_t part;
  TCCR2A = 0;
  TIMSK2 |= 1<<TOIE2;
  check_switches();
  byte index;
          // just pressed
          // just released
      pressed[index] = !currentstate[index];  // remember, digital HIGH means NOT pressed
  byte i;
  if (justpressed[1]) {
    justpressed[1] = 0;
  if(justpressed[2]){
    justpressed[2] = 0;
    sprintf(filename,"%d.wav", button2Counter);
    playcomplete(filename);
    Serial.println(filename);
    //check it at last file and reset if needed
    if(button2Counter == 4){
      button2Counter = 0;
    else{
      button2Counter++;
  playfile(name);
  wave.play();
toby
by xl97 on Thu Nov 15, 2012 1:25 pm
Hi toby-
see if this sketch works for your solution..
1.) (check yoru buttons, and how they are PHYSICALLY wired to the Arduino.. are they correct?, do they match the code?)
2.) just for fun.. to eliminate anything odd for now.. use a momentary switch for you first switch too..(all momentary)
3.) The 'fix':
*It plays 'cheer.wav' when first button is pressed
* All other files need to be named 1.wav, 2.wav, 3.wav, 4.wav & 5.wav...(I just used 5 as the cap..but it can be set in the code to be whatever you want.
// Solution sketch for this adafruit post:
// http://forums.adafruit.com/viewtopic.php?f=31&t=33737&sid=91be6ee3b73ff313c765f17ad1cec69d&p=170020#p170020
// created by: xl97
//import default/needed libraries
#include "WaveHC.h"
//custom defined variables
const int mainButton =  18;
const int secondaryButton =  16;
int trackCounter = 0;
int totalTracks = 5;
//project variables
//make button array for easy looping/checking
int buttons[] = {mainButton, secondaryButton};
// we will track if a button is just pressed, just released, or 'pressed' (the current state)
int freeRam(void)
  int free_memory;
  else {
  return free_memory;
    return;
  putstring(", ");
  while(1);
   //------------------[end init code]---------------------//
  byte i;
  // Set up serial port
  Serial.begin(9600);
  // Set-up pins not in button array
  // pin13 LED
  pinMode(13, OUTPUT);
    digitalWrite(buttons[i], HIGH);
    sdErrorCheck();
  uint8_t part;
  TCCR2A = 0;
  TIMSK2 |= 1<<TOIE2;
//--------------------[end set-up code]-----------------------//
//Add function for timer to execute.
  check_switches();
//check switches function (watched by timer repeatedly)
  //create vars to hold the states of the current button being checked
  byte index;
  //run through each button in the array to check if it is being pressed
    currentstate[index] = digitalRead(buttons[index]);   // read each button/store its status
        // just pressed
        //putstring("Button Pressed: ");
        //Serial.println(index,DEC);
      else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
        // just released
      pressed[index] = !currentstate[index];  // remember, digital HIGH means NOT pressed //commenting out stops file while pressed
    //update previous status to the current status
void loop(){
  //main button
    justpressed[0] = 0;
    playfile("cheer.wav");
  //second button (plays next track)
  if(justpressed[1]){
    justpressed[1] = 0;
    sprintf(filename,"%d.wav", trackCounter);
    playfile(filename);
    if(trackCounter == totalTracks){
      trackCounter = 0;
    else{
      trackCounter++;
    Serial.print(name);
    return;
    return;
  wave.play();
make sure files are on SD card
make any changes noted above
upload new sketch, post back
xl97
by adafruit_support_bill on Thu Nov 15, 2012 1:29 pm
There is no bounds-checking on the arrays. Based on the way the arrays are declared, the justreleased[] array is next to justpressed[] in memory. So justpressed[2] is most likely really justreleased[0].
As xl97 suggested. We should verify how you have everything connected before attempting to debug any further. Post a photo showing all your connections.
by toby on Thu Nov 15, 2012 1:50 pm
Alright all.
I'm going to go over my connections and code with a fine tooth comb and try the code you posted xl97. THANK YOU
The 2 button pins on the arduino connected to the wav shield are being driven high and low from a second arduino. I'm going to go over EVERYTHING today.
Yes, I do feel kind of sick right now over this.
toby
by xl97 on Thu Nov 15, 2012 2:00 pm
I updated my code a bit.. (above)
I was using your old code as base..etc..etc and copy/paste.. so I just used a known good sketch I had.. transplanted the data I posted for you to use/add..
and tested it.. seemed to work fine.
when I press the main button... it plays the cheers.wav file..
when I press the secondary button..
it plays 1.wav
when I press it again it plays: 2.wav
when I press it again.. plays: 3.wav..etc..
& when I press main button at any time.. it plays cheer.wav audio file.
xl97
by toby on Sat Nov 17, 2012 10:21 pm
I'm almost afraid to jinx this by saying everything is working but EVERYTHING IS WORKING!
I've yet to add the dozen of files I need to add for this project but the 4 test ones are playing perfectly.
I CAN'T THANK YOU BOTH ENOUGH.
SERIOUSLY.
If either of you find yourself in Pittsburgh, PA hit me up for a beer a coffee or both. :)
toby
by xl97 on Sat Nov 17, 2012 10:30 pm
hi- :)
not sure what code you're using.. but if its mine or a variant based off min, to work with more than the 5 tracks the demo code does..
change this line:
glad it all worked out. :)
xl97
by toby on Sat Nov 17, 2012 10:59 pm
I did end up using yours xl97 and I did notice and take note of that "int totalTracks = 5;" Thanks for bringing it to my attention though.
I'm glad we didn't have to go over soldering jobs, correct wire routing, etc. because this is the mess I'm dealing with....
toby
by xl97 on Thu Nov 22, 2012 1:00 pm
wow..
looks.. umm...... painful?
lol
glad everything is working out for you now!.
hooray Adafruit! :)
xl97
cron
