Arduino GPS shield
Arduino GPS shield
by daveoregon on Wed Oct 24, 2012 5:15 pm
HI, I have just assembled the GPS logger shield.....got the "SD_GPSLogger" code to compile (pls. see below) and the flashing LED on the GPS module is flashing red....
but I upload the code I get this msg
"avrdude: stk500_getsync () : not in sync: resp=0x00"
also, the seral monitor just shows jibberish
How can I fix this? Thanks!
Here's the code:
// Ladyada's logger modified by Bill Greiman to use the SdFat library
// this is a generic logger that does checksum testing so the data written should be always good
// Assumes a sirf III chipset logger attached to pin 2 and 3
#include <SD.h>
#include <avr/sleep.h>
#include "GPSconfig.h"
// If using Arduino IDE prior to 1.0,
// make sure to install newsoftserial from Mikal Hart
// http://arduiniana.org/libraries/NewSoftSerial/
#if ARDUINO >= 100
 #include <SoftwareSerial.h>
#else
 #include <NewSoftSerial.h>
#endif
// power saving modes
#define SLEEPDELAY 0    /* power-down time in seconds. Max 65535. Ignored if TURNOFFGPS == 0 */
#define TURNOFFGPS 0    /* set to 1 to enable powerdown of arduino and GPS. Ignored if SLEEPDELAY == 0 */
#define LOG_RMC_FIXONLY 0  /* set to 1 to only log to SD when GPD has a fix */
// what to log
#define LOG_RMC 1 // RMC-Recommended Minimum Specific GNSS Data, message 103,04
#define LOG_GGA 0 // GGA-Global Positioning System Fixed Data, message 103,00
#define LOG_GLL 0 // GLL-Geographic Position-Latitude/Longitude, message 103,01
#define LOG_GSA 0 // GSA-GNSS DOP and Active Satellites, message 103,02
#define LOG_GSV 0 // GSV-GNSS Satellites in View, message 103,03
#define LOG_VTG 0 // VTG-Course Over Ground and Ground Speed, message 103,05
// Use pins 2 and 3 to talk to the GPS. 2 is the TX pin, 3 is the RX pin
#if ARDUINO >= 100
 SoftwareSerial gpsSerial =  SoftwareSerial(2, 3);
#else
 NewSoftSerial gpsSerial =  NewSoftSerial(2, 3);
#endif
// Set the GPSRATE to the baud rate of the GPS module. Most are 4800
// but some are 38400 or other. Check the datasheet!
#define GPSRATE 4800
// Set the pins used
#define powerPin 4
#define led1Pin 5
#define led2Pin 6
#define chipSelect 10
#define BUFFSIZE 90
char buffer[BUFFSIZE];
uint8_t bufferidx = 0;
bool fix = false; // current fix data
bool gotGPRMC;    //true if current data is a GPRMC strinng
uint8_t i;
File logfile;
// read a Hex value and return the decimal equivalent
uint8_t parseHex(char c) {
  if (c < '0')
    return 0;
  if (c <= '9')
    return c - '0';
  if (c < 'A')
    return 0;
  if (c <= 'F')
    return (c - 'A')+10;
// blink out an error code
void error(uint8_t errno) {
  if (SD.errorCode()) {
    putstring("SD error: ");
    Serial.print(card.errorCode(), HEX);
    Serial.print(',');
    Serial.println(card.errorData(), HEX);
  while(1) {
    for (i=0; i<errno; i++) {
      digitalWrite(led1Pin, HIGH);
      digitalWrite(led2Pin, HIGH);
      delay(100);
      digitalWrite(led1Pin, LOW);
      digitalWrite(led2Pin, LOW);
      delay(100);
    for (; i<10; i++) {
      delay(200);
  WDTCSR |= (1 << WDCE) | (1 << WDE);
  WDTCSR = 0;
  Serial.begin(9600);
  Serial.println("\r\nGPSlogger");
  pinMode(led1Pin, OUTPUT);
  pinMode(led2Pin, OUTPUT);
  pinMode(powerPin, OUTPUT);
  digitalWrite(powerPin, LOW);
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card init. failed!");
    error(1);
  strcpy(buffer, "GPSLOG00.TXT");
  for (i = 0; i < 100; i++) {
    buffer[6] = '0' + i/10;
    buffer[7] = '0' + i%10;
    // create if does not exist, do not open existing, write, sync after write
    if (! SD.exists(buffer)) {
      break;
  logfile = SD.open(buffer, FILE_WRITE);
  if( ! logfile ) {
    Serial.print("Couldnt create "); Serial.println(buffer);
    error(3);
  Serial.print("Writing to "); Serial.println(buffer);
  // connect to the GPS at the desired rate
  gpsSerial.begin(GPSRATE);
  Serial.println("Ready!");
  gpsSerial.print(SERIAL_SET);
  delay(250);
#if (LOG_DDM == 1)
     gpsSerial.print(DDM_ON);
#else
     gpsSerial.print(DDM_OFF);
#endif
  delay(250);
#if (LOG_GGA == 1)
    gpsSerial.print(GGA_ON);
#else
    gpsSerial.print(GGA_OFF);
#endif
  delay(250);
#if (LOG_GLL == 1)
    gpsSerial.print(GLL_ON);
#else
    gpsSerial.print(GLL_OFF);
#endif
  delay(250);
#if (LOG_GSA == 1)
    gpsSerial.print(GSA_ON);
#else
    gpsSerial.print(GSA_OFF);
#endif
  delay(250);
#if (LOG_GSV == 1)
    gpsSerial.print(GSV_ON);
#else
    gpsSerial.print(GSV_OFF);
#endif
  delay(250);
#if (LOG_RMC == 1)
    gpsSerial.print(RMC_ON);
#else
    gpsSerial.print(RMC_OFF);
#endif
  delay(250);
#if (LOG_VTG == 1)
    gpsSerial.print(VTG_ON);
#else
    gpsSerial.print(VTG_OFF);
#endif
  delay(250);
#if (USE_WAAS == 1)
    gpsSerial.print(WAAS_ON);
#else
    gpsSerial.print(WAAS_OFF);
#endif
  //Serial.println(Serial.available(), DEC);
  char c;
  uint8_t sum;
  // read one 'line'
  if (gpsSerial.available()) {
    c = gpsSerial.read();
#if ARDUINO >= 100
    //Serial.write(c);
#else
    //Serial.print(c, BYTE);
#endif
    if (bufferidx == 0) {
      while (c != '$')
        c = gpsSerial.read(); // wait till we get a $
    buffer[bufferidx] = c;
#if ARDUINO >= 100
    //Serial.write(c);
#else
#endif
    if (c == '\n') {
      //putstring_nl("EOL");
      //Serial.print(buffer);
      buffer[bufferidx+1] = 0; // terminate it
      if (buffer[bufferidx-4] != '*') {
        // no checksum?
        Serial.print('*');
        bufferidx = 0;
        return;
      // get checksum
      sum = parseHex(buffer[bufferidx-3]) * 16;
      sum += parseHex(buffer[bufferidx-2]);
      // check checksum
      for (i=1; i < (bufferidx-4); i++) {
        sum ^= buffer[i];
      if (sum != 0) {
        //putstring_nl("Cxsum mismatch");
        Serial.print('~');
        bufferidx = 0;
        return;
      // got good data!
      gotGPRMC = strstr(buffer, "GPRMC");
      if (gotGPRMC) {
        // find out if we got a fix
        char *p = buffer;
        p = strchr(p, ',')+1;
        p = strchr(p, ',')+1;       // skip to 3rd item
        if (p[0] == 'V') {
          fix = false;
        } else {
          fix = true;
      if (LOG_RMC_FIXONLY) {
        if (!fix) {
          Serial.print('_');
          bufferidx = 0;
          return;
      // rad. lets log it!
      Serial.print(buffer);    //first, write it to the serial monitor
      Serial.print('#');
      if (gotGPRMC)      //If we have a GPRMC string
        // Bill Greiman - need to write bufferidx + 1 bytes to getCR/LF
        bufferidx++;
        digitalWrite(led2Pin, HIGH);      // Turn on LED 2 (indicates write to SD)
        logfile.write((uint8_t *) buffer, bufferidx);    //write the string to the SD file
        logfile.flush();
        if( != bufferidx) {
           putstring_nl("can't write!");
           error(4);
        digitalWrite(led2Pin, LOW);    //turn off LED2 (write to SD is finished)
        bufferidx = 0;    //reset buffer pointer
        if (fix) {  //(don't sleep if there's no fix)
          if ((TURNOFFGPS) && (SLEEPDELAY)) {      // turn off GPS module?
            digitalWrite(powerPin, HIGH);  //turn off GPS
            delay(100);  //wait for serial monitor write to finish
            sleep_sec(SLEEPDELAY);  //turn off CPU
            digitalWrite(powerPin, LOW);  //turn on GPS
          } //if (TURNOFFGPS)
        } //if (fix)
        return;
      }//if (gotGPRMC)
    bufferidx++;
    if (bufferidx == BUFFSIZE-1) {
       Serial.print('!');
       bufferidx = 0;
  } else {
void sleep_sec(uint16_t x) {
  while (x--) {
     // set the WDT to wake us up!
    WDTCSR |= (1 << WDCE) | (1 << WDE); // enable watchdog & enable changing it
    WDTCSR = (1<< WDE) | (1 <<WDP2) | (1 << WDP1);
    WDTCSR |= (1<< WDIE);
    set_sleep_mode(SLEEP_MODE_PWR_DOWN);
 //   sleep_enable();
    sleep_mode();
//    sleep_disable();
SIGNAL(WDT_vect) {
  WDTCSR = 0;
/* End code */
image of the shield attached to Arduino Uno
daveoregon
Re: Arduino GPS shield
by adafruit_support_bill on Thu Oct 25, 2012 5:54 am
That means that the upload failed. Check that you have the right board-type and COM port selected.
by arctic_eddie on Thu Oct 25, 2012 11:37 am
Selecting the wrong baud value for the serial monitor will produce trash characters. Connecting the GPS to serial port 0, RX0/TX0, will cause the sync problem. The SoftwareSerial port should be RX=2 and TX=3 and the baud should be 4800.
arctic_eddie
by daveoregon on Tue Nov 06, 2012 4:57 pm
Thanks very much.
I uploaded the "Blink" program
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
// the setup routine runs once when you press reset:
  // initialize the digital pin as an output.
  pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
  digitalWrite(led, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);               // wait for a second
  digitalWrite(led, LOW);    // turn the LED off by making the voltage LOW
and still get the
"avrdude: stk500_getsync(): not in sync: resp=0x00" response when uploading (why?...I did check serial port, it is indeed COM4)
Then I changed I changed the baud rate to 4800 (was 9600)
and now I get response on the COM4 serial monitor that looks like GPS data!
$GPGSA,A,3,29,21,30,26,18,05,02,15,16,25,12,,1.3,0.7,1.1*31
$GPRMC,205635.000,A,4435.0727,N,12314.5474,W,0.06,16.98,061112,,,D*48
$GPGGA,205636.000,4435.0727,N,12314.5474,W,2,11,0.7,84.8,M,-20.9,M,1.8,0000*78
$GPRMC,205636.000,A,4435.0727,N,12314.5474,W,0.02,18.18,061112,,,D*49
$GPGGA,205637.000,4435.0727,N,12314.5474,W,2,11,0.7,84.9,M,-20.9,M,1.8,0000*78
$GPRMC,205637.000,A,4435.0727,N,12314.5474,W,0.06,11.93,061112,,,D*46
$GPGGA,205638.000,4435.0726,N,12314.5474,W,2,11,0.7,84.9,M,-20.9,M,2.8,0000*75
$GPRMC,205638.000,A,4435.0726,N,12314.5474,W,0.07,23.02,061112,,,D*40
$GPGGA,205639.000,4435.0726,N,12314.5474,W,2,11,0.7,84.9,M,-20.9,M,3.8,0000*75
$GPGSV,3,1,12,29,81,084,44,21,48,264,39,05,42,057,39,25,32,193,33*75
$GPGSV,3,2,12,30,28,307,39,18,17,201,37,26,13,101,40,02,10,071,35*75
$GPGSV,3,3,12,15,09,135,39,16,06,327,39,12,06,170,33,31,03,264,*75
$GPRMC,205639.000,A,4435.0726,N,12314.5474,W,0.13,23.54,061112,,,D*47
$GPGGA,205640.000,4435.0726,N,12314.5474,W,2,11,0.7,85.0,M,-20.9,M,4.8,0000*74
etc.
Looks like I have something to work with now, thanks!
daveoregon
by daveoregon on Tue Nov 06, 2012 7:36 pm
I think I get it, now. The reason the code did not upload is that the Arduino micro has been removed!
The instructions said the micro had to be removed because it was "in the way" (http://www.ladyada.net/make/gpsshield/d ... nnect.html)....I presume this means just in the way for debugging purposes (?)
daveoregon
by daveoregon on Tue Nov 06, 2012 7:40 pm
One suggestion: the assy instructions for the GPS logger shield are a little confusing in that there is a mix of images of version 1.0 and 1.1. Thanks.
daveoregon
by daveoregon on Tue Nov 13, 2012 3:25 pm
Been playing with the finished shield, it works great, but I haven't figured how to get it to report anything but the $GPRMC NEMA sentence. I tried modifying the code so that I turned "ON" all the various logging modes but that didn't work, my log file had nothing in it....even setting only one of the other logging states (say, GSA) to "1" didn't work. Any suggestions?
Here's the code section I'm talking about
// what to log
#define LOG_GGA 1 // GGA-Global Positioning System Fixed Data, message 103,00
#define LOG_GLL 1 // GLL-Geographic Position-Latitude/Longitude, message 103,01
#define LOG_GSA 1 // GSA-GNSS DOP and Active Satellites, message 103,02
#define LOG_GSV 1 // GSV-GNSS Satellites in View, message 103,03
#define LOG_VTG 1 // VTG-Course Over Ground and Ground Speed, message 103,05
and here is the entire program:
// what to log
THANKS!
daveoregon
by arctic_eddie on Tue Nov 13, 2012 5:14 pm
You may be getting only the first sentence that's enabled, RMC. Set all to 0 except GGA. This one contains time, lon, lat, alt, and some satellite data. The EM-406A spec sheet has info on sentence content and formatting. You can recover the data in a sketch by scanning the sentence and extracting text between the appropriate two commas. String variables have commands to do this kind of stuff.
arctic_eddie
by cbausmart on Thu Nov 22, 2012 11:51 am
Hello world! anyone of you knows how to add some sensors to this definition?? I mean, how to logg the sensor data in the SDcard, geolocating the values. I took the same deffinition of Ladyada, but I don't know how to add some sensor code.
:wink:
#include <SD.h>
#if ARDUINO >= 100
#else
#endif
// what to log
#if ARDUINO >= 100
#else
#endif
#define powerPin 4
#define led1Pin 5
#define led2Pin 6
#define BUFFSIZE 90
uint8_t i;
File logfile;
  if (c < '0')
    return 0;
  if (c <= '9')
    return c - '0';
  if (c < 'A')
    return 0;
  if (c <= 'F')
    Serial.print(',');
  while(1) {
      delay(100);
      delay(100);
    for (; i<10; i++) {
      delay(200);
  WDTCSR = 0;
  Serial.begin(9600);
    error(1);
      break;
  if( ! logfile ) {
    error(3);
  delay(250);
#if (LOG_DDM == 1)
#else
#endif
  delay(250);
#if (LOG_GGA == 1)
#else
#endif
  delay(250);
#if (LOG_GLL == 1)
#else
#endif
  delay(250);
#if (LOG_GSA == 1)
#else
#endif
  delay(250);
#if (LOG_GSV == 1)
#else
#endif
  delay(250);
#if (LOG_RMC == 1)
#else
#endif
  delay(250);
#if (LOG_VTG == 1)
#else
#endif
  delay(250);
#if (USE_WAAS == 1)
#else
#endif
  char c;
  uint8_t sum;
  // read one 'line'
#if ARDUINO >= 100
    //Serial.write(c);
#else
#endif
      while (c != '$')
#if ARDUINO >= 100
    //Serial.write(c);
#else
#endif
    if (c == '\n') {
        // no checksum?
        Serial.print('*');
        bufferidx = 0;
        return;
      // get checksum
      // check checksum
        sum ^= buffer[i];
      if (sum != 0) {
        Serial.print('~');
        bufferidx = 0;
        return;
      // got good data!
      if (gotGPRMC) {
        char *p = buffer;
        if (p[0] == 'V') {
          fix = false;
        } else {
          fix = true;
        if (!fix) {
          Serial.print('_');
          bufferidx = 0;
          return;
      Serial.print('#');
        bufferidx++;
        logfile.flush();
        if( != bufferidx) {
           error(4);
          } //if (TURNOFFGPS)
        } //if (fix)
        return;
      }//if (gotGPRMC)
    bufferidx++;
       Serial.print('!');
       bufferidx = 0;
  } else {
  while (x--) {
 //   sleep_enable();
    sleep_mode();
//    sleep_disable();
SIGNAL(WDT_vect) {
  WDTCSR = 0;
/* End code */
cbausmart
