Adafruit Motor/Stepper/Servo Shield for Arduino kit
by zero25 on Sun Nov 04, 2012 12:24 pm
I have Adafruit Motor/Stepper/Servo Shield for Arduino kit and arduino uno R3
after i conect the Adafruit Motor/Stepper/Servo Shield for Arduino kit to arduino uno R3
and i try to upload code i get an error:
avrdude: stk500_getsync(): not in sync: resp=0x00
help me im newbie
sorry for my english
zero25
Re: Adafruit Motor/Stepper/Servo Shield for Arduino kit
by adafruit_support_bill on Sun Nov 04, 2012 12:28 pm
Are you able to upload to the UNO without the shield attached?
by zero25 on Mon Nov 05, 2012 12:58 pm
yes
im able upload code without shield attached on arduino
zero25
by adafruit_support_bill on Mon Nov 05, 2012 1:15 pm
It sounds like you may have a short-circuit on the shield. Post photos of the front and back of the shield and we will check your assembly.
by zero25 on Mon Nov 05, 2012 1:29 pm
i think like that
because i assamble like that
if i get a short circuit it is make my shield is damage?
zero25
by zero25 on Mon Nov 05, 2012 1:34 pm
sometime i can upload my code
but after my code uploading is done my motorDC is not give a some action
but at serial monitor it is work
im use motorDC 12v 0.85A
zero25
by adafruit_support_bill on Mon Nov 05, 2012 1:59 pm
Those photos are not helpful. I need to see all of the components on the front of the board and all of the soldering on the back of the board.
I don't understand your wiring either. The shield is designed to plug directly into the Arduino as in the photo below:
Does the motor move at all? With all those jumper wires, you may have a loose connection somewhere.
The L293D chips in the shield are only rated for 0.6A motors. Read this FAQ for details on how to increase that rating: viewtopic.php?f=31&t=26873
by zero25 on Mon Nov 05, 2012 2:03 pm
how much max ampere this motor shield can run for 1 MotorDC ?
zero25
by adafruit_support_bill on Mon Nov 05, 2012 2:32 pm
Using the standard chips in the kit, 0.6A.
With modifications, up to about 2.0A. Please read this FAQ for all the details: viewtopic.php?f=31&t=26873
by zero25 on Tue Nov 06, 2012 11:04 am
for that i must use extra power?
or i can just use power from usb ?
zero25
by adafruit_support_bill on Tue Nov 06, 2012 12:38 pm
USB can only supply 500mA @5v. It is not a good idea to run motors from USB power.
by zero25 on Tue Nov 06, 2012 1:27 pm
for running this shield what is requirtment power?
if i went tu running motorDC 12v how to configure the shield for can be work perfectly?
zero25
by adafruit_support_bill on Tue Nov 06, 2012 1:37 pm
For a 12v motor, you must use an external power supply. Please read theFAQ for details on how to connect the external supply: viewtopic.php?f=31&t=26873
by zero25 on Thu Nov 08, 2012 2:26 pm
no w i success for upload code to my arduino whit the shield is connected to my arduino
but at the code i use i decclare M1/ M2/ M3/ M4 another one is work
but if i declare another one M1/2/3/4 this motor DC is nothing have a response
but if i connected the motor DC at gnd and M4 this motor will work but that work not same like code i uploaded.
can you give me another full code for running the motorDC ?
zero25
by adafruit_support_bill on Thu Nov 08, 2012 2:39 pm
I don't understand the problem you are trying to describe. If you post a diagram of your connections and the code you are using I might be able to help.
