Arduino Uno assembled in US now available in the Store @arduino & Adafruit #TeamArduinoCC
1.8" TFT Shield
1.8" TFT Shield
by dchengster on Tue Nov 06, 2012 1:03 am
I just got my order in the mail today.
Soldered the pins onto the shield, loaded the 2 libraries onto Arduino 1.0.1 and uploaded the shield test sketch.
Not currently using an SD card, upon finishing, screen is white. Nothing comes up.
Serial monitor shows that the joystick is working and when pressed in, it attempts to read the non-existing SD card.
Does this sketch only read an SD card? Is there another way to test the screen when not using a SD?
dchengster
Re: 1.8" TFT Shield
by adafruit_support_bill on Tue Nov 06, 2012 7:13 am
It should print text to the screen when moving the joystick. What kind of Arduino do you have this attached to?
If you post photos showing all your soldering, we'll check it out.
Re: 1.8" TFT Shield
by dchengster on Tue Nov 06, 2012 9:55 pm
photo 1.JPG (640.51 KiB) Viewed 1720 times
photo 2.JPG (413.67 KiB) Viewed 1720 times
photo 3.JPG (600.74 KiB) Viewed 1720 times
dchengster
Re: 1.8" TFT Shield
by dchengster on Tue Nov 06, 2012 9:57 pm
Sorry about the upside down photos, hate the Apple sometimes.
I'm using a Duemilanove 328, powered from USB.
When I press reset on the shield and wait about 4 seconds, the white screen goes away and a 'snow' screen appears for 0.5 seconds and then back to the white screen.
photo 4.JPG (565.34 KiB) Viewed 1720 times
dchengster
Re: 1.8" TFT Shield
by adafruit_support_bill on Wed Nov 07, 2012 7:13 am
You should be seeing text on a black background on the screen when you move the joystick. I don't see any problem with your soldering.
Contact support@adafruit.com with a link to this thread for a replacement.
Re: 1.8" TFT Shield
by dchengster on Wed Nov 07, 2012 10:31 am
Will do, thanks for your help.
dchengster
Re: 1.8" TFT Shield
by shiggity on Sun Nov 11, 2012 7:46 am
I am having the exact same problem with the 1.8" TFT Shield, Uno R3 and the ST7735 & Adafruit GFX libraries.
The screen is all white and Serial Monitor shows that the joystick works.
Any news on this or am I looking at a replacement?
shiggity
Re: 1.8" TFT Shield
by adafruit_support_bill on Sun Nov 11, 2012 8:52 am
@shiggity - post a photo showing all your soldering.
Re: 1.8" TFT Shield
by attila.aranyi on Sun Nov 11, 2012 3:04 pm
Just received the shield 2 days ago and I'm having the same problem... white screen, nothing displayed - console log looks good, picture is loaded from SD
Arduino is an UNO R3 from Adafruit (bought with the starter pack (the BMP085 works properly - same shipping)
Any idea how to fix?
Thank you,
attila.aranyi
Re: 1.8" TFT Shield
by randrews on Sun Nov 11, 2012 6:13 pm
I have this exact same problem:
I'm using a brand-new Arduino Uno, I'm able to run the ASCII chart sketch on it no problem. When I run the shield test sketch (using either the red-label init line or the green-label one, doesn't matter) the joystick prints its status to the serial port but the screen is just solid white.
Here are links to some pictures of my solder joints; I think they're fine because the backlight comes on and the joystick works: http://www.flickr.com/photos/84998402@N ... 985017564/
There's nothing obviously wrong with the screen, it's not taped very well on to the PCB but the ribbon cable looks fine.
So, is there anything I'm doing wrong, or can I get a replacement shield? Thanks!
randrews
Re: 1.8" TFT Shield
by adafruit_support_bill on Sun Nov 11, 2012 6:29 pm
@Attila - Please post photos showing all your soldering.
@randrews - Soldering looks good. Contact support@adafruit.com with a link to this thread for a replacement.
Re: 1.8" TFT Shield
by adafruit on Mon Nov 12, 2012 10:46 am
Hi guys, please hold off on getting replacement shields just yet - its almost certainly not a hardware issue. we fixed a few things in the latest version of the library and it may have broken some stuff (as the IDE's do change a little sometimes)
Please try deleting the ST7735 library and loading this one
https://github.com/adafruit/Adafruit-ST ... 6af679.zip
and let us know if that helps! :)
Re: 1.8" TFT Shield
by attila.aranyi on Mon Nov 12, 2012 2:31 pm
Hi all,
just tested and the shieldtest works - graphics test and the highspeed graphics test does not - have to check the changes you made .... I'll however attach the picture as there is pretty much backlight leakage - seems the lcd isn't properly glued - if i gently press, it will stick to the PCB for few seconds... maybe a minute - any quick fix for this ?
-image attached-
attila.aranyi
Re: 1.8" TFT Shield
by randrews on Mon Nov 12, 2012 3:46 pm
Cool, I'll try the new library when I get home. Hope it works! I'm having the same issue with the screen being unstuck from the PCB; I was going to try a chunk of foam tape or something (or just build the enclosure to hold it on). Think that'll help?
Also, I'm working on a design for a 3d-printed enclosure for an Arduino + this shield. When it's finished, anyone want one?
randrews
Re: 1.8" TFT Shield
by randrews on Mon Nov 12, 2012 7:46 pm
Yep, the new library works perfectly on shieldtest, doesn't work on graphicstest, but in a little bit I'll figure out what the diff is and I bet graphicstest will work too. It's definitely not a hardware problem.
Unfortunately I placed an order for a replacement last night, and it already shipped.
randrews
