PN532 NFC Shield
PN532 NFC Shield
by schizophrene on Sun Nov 11, 2012 4:17 pm
Hi guys,
Is anyway to use the shield as the breakout board, with a FTDI cable?
I mean, by wiring Tx and Rx directly on the shield?
Thanks for response
schizophrene
Re: PN532 NFC Shield
by adafruit_support_bill on Mon Nov 12, 2012 6:44 am
There is no FTDI cable header on the shield. But all the same signals are available and it could be done with some hacking.
by schizophrene on Mon Nov 12, 2012 2:17 pm
Hello, and thank you for your response :)
Yes, I know that there is no FTDI header on the shield. But I can see SDA and SCL pin (in the up left of the picture) on the board. I can use it for use with FTDI cable?
schizophrene
by adafruit_support_bill on Mon Nov 12, 2012 2:28 pm
As I said: all the same signals are there and can be used with some hacking. If you are using the shield on an Arduino - any use of i2c or analog 4 & 5 will interfere with your FTDI use.
by schizophrene on Mon Nov 12, 2012 3:46 pm
For an experience, I will use the shield without the Arduino That's why I ask you :)
schizophrene
by xfile on Tue Nov 13, 2012 9:55 am
I need to test it, I think you can remove 2 resistor 10K below pads SEL0 and SEL1, so now you have pin 16 and pin 17 free, you can use pads of 2 resistors to "solder" to your microcontroller or gnd(select HSU host protocol).
I repeat: I need to test it, but should be correct.
xfile
