Motor shield question
by daveoregon on Thu Nov 22, 2012 2:18 am
Hi, My motor shield seems to be working, except for the servo. I had been hoping that the shield would allow me to run a reasonably-sized stepper (as the one from the scanner shown in the photo, loaded and able to drive the scanner "sled" along its slider bar) and DC motor (I used a dinky one from a CD player in the photo, but would like to be able to drive larger ones, and move printer carriages back and forth), but see that the 1 amp limit (at least for steady-state current) will be quite limiting.
Any advice on how to get a more "industrial" version of this board, to be able to move bigger loads without eventually frying the chips?
I noticed that the motor drivers were *not* getting warm (at least warm enough for me to sense with my finger), even though they were (I think) supplying much more than 1 amp. (My power supply indicated it was supplying more than 5 Amps at 4.5 Volts when I ran the stepper from the scanner, which was not attached to the scanner belt; i.e. the motor was under very little load.)
I'll spend some more time trying to figure why the servo was not working, I have had success driving servos straight from the Arduino in the past, but have had jitter/stability issues.
Thanks in advance for your help.
"Motor party" code is here:
// Adafruit Motor shield library
// copyright Adafruit Industries LLC, 2009
// this code is public domain, enjoy!
#include <AFMotor.h>
#include <Servo.h>
// DC motor on M2
AF_DCMotor motor(2);
// DC hobby servo
Servo servo1;
// Stepper motor on M3+M4 48 steps per revolution
AF_Stepper stepper(48, 2);
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Motor party!");
  // turn on servo
  servo1.attach(9);
  // turn on motor #2
  motor.setSpeed(200);
  motor.run(RELEASE);
int i;
// Test the DC motor, stepper and servo ALL AT ONCE!
  motor.run(FORWARD);
  for (i=0; i<255; i++) {
    servo1.write(i);
    motor.setSpeed(i);
    stepper.step(1, FORWARD, INTERLEAVE);
    delay(3);
  for (i=255; i!=0; i--) {
    servo1.write(i-255);
    motor.setSpeed(i);
    stepper.step(1, BACKWARD, INTERLEAVE);
    delay(3);
  motor.run(BACKWARD);
    servo1.write(i);
    motor.setSpeed(i);
    delay(3);
    stepper.step(1, FORWARD, DOUBLE);
    motor.setSpeed(i);
    stepper.step(1, BACKWARD, DOUBLE);
    delay(3);
Here's the "motor party" set up
daveoregon
Re: Motor shield question
by adafruit_support_bill on Thu Nov 22, 2012 7:32 am
See the "I Need More Power" section of this FAQ: viewtopic.php?f=31&t=26873
by daveoregon on Thu Nov 22, 2012 5:48 pm
Motor shield can drive either the scanner bed (stepper) or CD rack (DC motor)...in the photo the latter is connected
Very good, thanks. I realize now I was mis-reading my ammeter and the current draws were much smaller: 4.5Volts & 0.65 Amps for the scanner, and 5V & 0.15-0.2Amps for the CD player DC motor. I can run the scanner sled back and forth OR run the CD rack in and out, success!
My Heathkit variable power supply (20V, 0.5A rating) is able to handle one of these at a time, but not both, at least not both consistently. I still have not succeeded in getting the servos to work, though the pins are powered, and I've tried running them alone (no stepper or DC motor at the "party").
Based on the FAQ page, I'll try powering the servos independently.
What is the maximum external voltage I can safely apply to the motor shield? As I mentioned, my variable DC power supply has a 20V, 0.5Amp rating....I usually set it at 9Volts and "get what I get" for amperage.
The stepper motor on the scanner
daveoregon
by adafruit_support_bill on Fri Nov 23, 2012 7:36 am
If you post photos of the front & back of the board, we'll check for any assembly issues.
It will handle up to 25v with the stock capacitors. If you upgrade C7 & C8 to higher voltage ratings, the H-bridges will take up to 36v.
by daveoregon on Sat Nov 24, 2012 12:11 am
Thanks for the info and help. Attached please find images of the front and back of the shield, wired up to run a DC motor.
Any assistance/advice on what I need to get the servos working is much appreciated!
Front of shield
back of shield, photo 2
Back of shield, photo 1
daveoregon
by adafruit_support_bill on Sat Nov 24, 2012 7:52 am
From what I can see, the soldering looks fine. Double check digital pins 9 and 10, as well as the servo header to be sure.
* Make sure that you have the servos connected to the right ports: Servo 2 is controlled by pin 9. Servo 1 is controlled by pin 10.
* Make sure you have the servos plugged in correctly. The signal wire (yellow or white) should be on the same side as the "SER1/SERVO2" label.
If it still doesn't work, post the code you are using.
by daveoregon on Thu Jun 20, 2013 2:24 pm
I love this motor shield, have gotten lots of good use out of it with both steppers and DC motors....presently have an app in which I think I may have damaged the analog input pins. I have a pressure transducer which can provide a negative output voltage which I fed into A0. How negative a voltage can I put into an analog output on this board and not have trouble? Thanks.
daveoregon
by adafruit_support_bill on Thu Jun 20, 2013 4:35 pm
A negative voltage on an analog input will not damage the shield itself. It will damage the Atmega 328P processor on your Arduino.
According to the Atmega 328 data sheet: http://www.atmel.com/Images/doc8161.pdf
The absolute maximum range of voltages on any pin is -0.5v to 5.5v. Beyond that, "may cause permanent damage to the device"
Fortunately, unless you have one of the SMT versions of the Uno, your processor chip is replaceable for $5.95 : http://www.adafruit.com/products/123
by daveoregon on Sat Dec 21, 2013 11:27 pm
Thanks, that worked.
Now I have a version 2.0 motor shield.
I have it mounted on an Arduino mega and when I attempt to upload code (e.g. Motor party) it takes a VERY long time and then I receive this message:
avrdude: stk500_getsync(): not in sync: resp=0x00
What's the matter?
daveoregon
by daveoregon on Sat Dec 21, 2013 11:33 pm
Thanks, I figured out, I had the board set to the wrong version of the Mega (I use the 2560)
daveoregon
