Reset button not working on LCD shield
by stefan.wiswedel on Thu Nov 29, 2012 12:36 am
Hey all,
SO, I have the 16x2 standard LCD shield (http://www.adafruit.com/products/772) and it all works beautifully except for the reset button. I am using it in 'detached' mode at the moment but it didn't work while attached either.
Any ideas?
SW
stefan.wiswedel
Re: Reset button not working on LCD shield
by adafruit_support_bill on Thu Nov 29, 2012 8:08 am
If you post photos of the front & back of the board, we'll check things out. For the reset to work detached you would need run a wire for the reset pin in addition to power and I2C. But if it doesn't work attached either, something is amiss...
by pascal74 on Fri Feb 15, 2013 3:55 pm
Good evening,
I have the same problem with the reset button :(
My shield as you ask
Thanks for your help
PJ
pascal74
by adafruit_support_bill on Fri Feb 15, 2013 4:09 pm
You only have 4 wires there. For the reset to work you need to connect the reset pin too.
by pascal74 on Sat Feb 16, 2013 2:17 am
Thanks for your answer.
Where shall i find the label for the pins ?
And how to connect the reset button to my Arduino Uno ?
Regards
pascal74
by adafruit_support_bill on Sat Feb 16, 2013 8:29 am
Find the pin labeled "RESET" on your UNO (It is right next to the 3.3v pin). Connect that to the corresponding pin on the shield.
