Create custom charactors on LCD Shield Kit w/ 16x2 Character Display
by Le-bo2d9 on Sat Dec 01, 2012 3:43 am
I bought the LCD Shield Kit w/ 16x2 Character Display shield.
Is it possible to display custom characters on the display?
Kind regards
Koen
Le-bo2d9
Re: Create custom charactors on LCD Shield Kit w/ 16x2 Character Display
by Le-bo2d9 on Sat Dec 01, 2012 9:19 am
I have found the solution.
Below you can find a small example
#include <Wire.h>
#include <Adafruit_MCP23017.h>
#include <Adafruit_RGBLCDShield.h>
byte smiley[8] = {
  B00000,
  B10001,
  B00000,
  B00000,
  B10001,
  B01110,
  B00000,
Adafruit_RGBLCDShield lcd = Adafruit_RGBLCDShield();
// Pin definitions
const byte
  RTC_GND_PIN = A2,  //I use A2 for GND and A3 for VCC to power the I2C equipment
  RTC_VCC_PIN = A3;
 void setup(){
  pinMode(RTC_GND_PIN, OUTPUT);
  pinMode(RTC_VCC_PIN, OUTPUT);
  digitalWrite(RTC_GND_PIN,LOW);
  digitalWrite(RTC_VCC_PIN,HIGH);
   lcd.createChar(0, smiley);
  lcd.begin(16, 2);
  lcd.write(0);
void loop() {}
Kind regards
Koen
Le-bo2d9
by mechatweak on Sat Mar 29, 2014 3:11 pm
I know this is an old post, but the reply for Le-bo2d9 did not work for me. Instead of a smiley I got pixel garbage.
After a little experimentation I found that the problem goes away if you put lcd.begin above lcd.createChar.
I did not have to call any pinMode or digitalWrite functions and did not have to setup any pin definitions.
This seems like an easier fix, so I thought I would post...
mechatweak
