Hey to everyone,
i was trying to reproduce what "uniapa" said about deselecting each tag after reading. It was not working out for me. I was using the iso14443a_uid example from the arduino library. I get exactly the same behavior as if i did not add the code that "uniapa" mentioned. How exactly where you calling the readPassiveTargetID function in your arduino sketch? Any other modifications.
I want to read exactly 2 cards stacked above each other.
thank you in advance
PN532 NFC/RFID reading multiple tags
Re: PN532 NFC/RFID reading multiple tags
It's possible, but our library doesn't support multiple cards.
- andystr
Thank you for your answer.
Your library actually does support two cards with minor modification. All i had to do was change the readPassiveTargetID function. Basically you only need to change this portion of the code:
I adjusted the maximum amount of cards to two and increased the packetbuffer to 31 to store all values of two tags.
This works as expected, but the reading process gets to slow for me, it takes drastically longer than reading with the maximum amount of cards set to 1.
Thats why i wanted to know if the method that "uniapa" described actually worked, because i wasnt able to reproduce what he said.
The way he explained he deactivates each tag in the field by using the INDESELECT command at the end of readPassiveTargetID. But the way i understand this is, the tags get activated again in the next loop when the reader is searching for them. So i dont see how this should work.
Any hints anybody?
Best regards
Andy
boolean Adafruit_PN532::readPassiveTargetID(uint8_t cardbaudrate, uint8_t * uid1, uint8_t * uid2, uint8_t * uidLength) {
pn532_packetbuffer[0] = PN532_COMMAND_INLISTPASSIVETARGET;
pn532_packetbuffer[1] = 2; // max 2 cards at once
pn532_packetbuffer[2] = cardbaudrate;
if (! sendCommandCheckAck(pn532_packetbuffer, 3))
return 0x0; // no cards read
// read data packet
readspidata(pn532_packetbuffer, 31);
// check some basic stuff
/* ISO14443A card response should be in the following format:
byte Description
b0..6 Frame header and preamble
b7 Tags Found
b8 Tag Number (only one used in this example)
b9..10 SENS_RES
b11 SEL_RES
b12 NFCID Length
b13..b19 NFCID
for 2 mifare ultralight tags:
b20 Tag Number
b21..22 SENS_RES
b23 SEL_RES
b24 NFCID Length
b25..b31 NFCID */
Any hints anybody?
Best regards
Andy
- lukejones27
I recently started a project which I aim to read multiple tags and come across this forum thread. Has there been any head way made with being able to read multiple tags? I was looking at having multiple tags on the shield and reading each one then ignoring that tag an reading another then ignoring that tag and the previous etc.
Any help or information on this would be appreicated!
