motor shield servo not working
by berko on Thu Dec 20, 2012 11:35 pm
I just finished getting the motor shield soldered up and just trying to get a servo running (starting simple, i thought).
i am powering my UNO via usb, the sketch is uploading without error (tried both example > servo > sweep and knob).
i have the power jumper in place (as i thought the tutorial said that was fine for using a servo) and the power light lights up on both the UNO and the shield.
When i first plug the UNO in via USB the servo makes a little movement that lasts a few microseconds as if to tease me and say, i am getting power, but ha ha you can't control me.
it is taunting me.
any ideas on where to start trying to figure out what is happening.
i am using the smaller servo that came with the motor party pack (tower pro SG92R).
thanks for any help you can give.
-jon
berko
Re: motor shield servo not working
by adafruit_support_bill on Fri Dec 21, 2012 6:46 am
First thing to try - move the servo connector to the other servo header on the shield.
If that doesn't work, post photos of the front & back of the board and we'll check your assembly.
by berko on Fri Dec 21, 2012 9:56 am
And to make that work I just change the pin from pin9to pin10?
berko
by adafruit_support_bill on Fri Dec 21, 2012 10:11 am
Just move the connector without changing the code. There was an error in one of the examples that mislabeled the pins. Let's rule that out before looking further.
by berko on Fri Dec 21, 2012 11:25 pm
ok, that did the trick.
its works while connected to servo2 (as labelled on the board) and in the sketch:
myservo.attach(9);
connected to "servo1" and pin10 also works.
isn't that backwards?
berko
by adafruit_support_bill on Sat Dec 22, 2012 3:10 pm
Yes that is backwards. We need to fix the docs. Sorry for the confusion.
by berko on Sat Dec 22, 2012 5:05 pm
no problem. thanks for the help.
next up...getting a battery pack for the other motors and getting those working.
more questions to come i am sure.
happy holidays.
-jon
berko
by robnapier on Fri Jan 25, 2013 9:49 pm
I'm using MotorParty and Sweep, which both indicate that they use pin 9. Looking at the board, it indicates that pin 9 is "S1". But I have to connect to Servo 2 to work. Does this mean the silkscreen on the board is incorrect?
robnapier
by adafruit_support_bill on Sat Jan 26, 2013 7:34 am
Yes. Servo 2 is pin 9 and Servo 1 is pin 10.
