USE UPS NEXT DAY AIR FOR ANY USA ORDER BEFORE 11AM ET *TODAY* 12/19/2014 TO GET YOUR PACKAGE IN TIME FOR XMAS - PLEASE SEE OUR SHIPPING DEADLINE NOTICE FOR MORE DETAILS!
CardInfo reports wrong size on Logger Shield
by pgrunwald on Mon Dec 24, 2012 11:40 pm
I have an 8GB Samsung Micro SD Card in an adapter. I formatted the card with the SD Formatted Utility from the SD site and it and Windows reports 7.4GB usable area.
I get this when I run CardInfo:
Initializing SD card...
Card type: SDHC
Volume type is FAT32
Volume size (bytes): 3658711040
Volume size (Kbytes): 3572960
Volume size (Mbytes): 3489
Files found on the card (name, date and size in bytes):
DATALOG.TXT   2000-01-01 01:00:00 2886
Datalogger worked find and the file is readable in Windows. What am I missing?
Paul
pgrunwald
Re: CardInfo reports wrong size on Logger Shield
by fat16lib on Wed Dec 26, 2012 5:27 pm
CardInfo has a bug that caused it to report the wrong size for cards larger than 4 GB.
CardInfo uses a uint32_t which is limited to 4,294,967,295 so you get some truncated wrong answer.
  uint32_t volumesize;
You can change the section that prints the volume type and size like this
  // print the type and size of the first FAT-type volume
  Serial.print("\nVolume type is FAT");
  Serial.println(volume.fatType(), DEC);
  Serial.println();
  volumesize = volume.blocksPerCluster();    // clusters are collections of blocks
  volumesize *= volume.clusterCount();       // we'll have a lot of clusters
  if (volumesize < 0X800000) {
    volumesize *= 512;                        // SD card blocks are always 512 bytes
    Serial.print("Volume size (bytes): ");
    Serial.println(volumesize);
    volumesize /= 1024;
  } else {
     volumesize /= 2;
  Serial.print("Volume size (Kbytes): ");
  Serial.print("Volume size (Mbytes): ");
  volumesize /= 1024;
Then an 8GB card will print something like this:
Volume size (Kbytes): 7753728
Volume size (Mbytes): 7572
And a 2GB will print the byte count:
Volume size (bytes): 1977286656
Volume size (Kbytes): 1930944
Volume size (Mbytes): 1885
fat16lib
by pgrunwald on Wed Dec 26, 2012 5:49 pm
pgrunwald
