Current needed
Current needed
by dehein2 on Wed Dec 26, 2012 10:53 am
i want to connect 2 6V DC Motors. Should i connect exactly 6V to the Power-In connector on the shield, or can (should) i attach higher currents?
dehein2
Re: Current needed
by adafruit_support_rick on Wed Dec 26, 2012 2:19 pm
6V is voltage, not current. If you want to drive any number of 6V motors, you will always use a 6V supply.
What you're interested in is the Amperage (i.e., current) drawn by the motors. Find out the current required by each motor, and multiply that by the number of motors. If, for example, your 6V motors draw 1A each, then you would need at least a 6V 2A supply.
Re: Current needed
by dehein2 on Sun Dec 30, 2012 10:28 am
sorry for the confusion ;
.. and thanks for the answer
dehein2
Re: Current needed
by adafruit_support_bill on Sun Dec 30, 2012 10:52 am
If you are talking about the Adafruit motor shield, keep in mind that the maximum current per motor is 0.6A. There are ways to increase this if needed. They are discussed in this FAQ: viewtopic.php?f=31&t=26873
