Code doesnt work
- Franklin97355
Re: Code doesnt work
@Shug White and you have the library installed in your sketchbook/libraries folder? What do you see when you go to Sketch > Import library? Do you see it there?
- 2014-07-19_19h51_23.png (56.08 KiB) Viewed 209 times
- adafruit_support_rick
Please post a screen shot showing your installation of the library, as was done in this thread:
http://adafruit.com/forums/viewtopic.ph ... 21#p179090
- shug white
There was a tutorial that told me that if I'm using the leonardo board with this rfid reader I should break the contact at pin2 and IRQ pin
*This is where I'm messing up...I have to solder the wire to 'Pin 4 or above' and not just break the connection between IRQ and 2...
Sorry for being a noob, thanks for the help...will follow up with success
