pn532 shield
pn532 shield
by dogan on Wed Dec 26, 2012 6:36 pm
I want to read desfire ev1 card.I have arduino uno + nfc shield .I can read/write mifare classic card.How to find read/write code for desfire ev1 card.Any suggestion link or tutorial?
dogan
Re: adafruit shield
by franklin97355 on Wed Dec 26, 2012 6:47 pm
What have you tried so far?
Have you found and read the specifications for this type of card?
franklin97355
Re: adafruit shield
by dogan on Wed Dec 26, 2012 7:01 pm
I succesfully read mifare classic card with this code .
    @file     readMifare.pde
    @author   Adafruit Industries
   @license  BSD (see license.txt)
    This example will wait for any ISO14443A card or tag, and
    depending on the size of the UID will attempt to read from it.
    If the card has a 4-byte UID it is probably a Mifare
    Classic card, and the following steps are taken:
    - Authenticate block 4 (the first block of Sector 1) using
      the default KEYA of 0XFF 0XFF 0XFF 0XFF 0XFF 0XFF
    - If authentication succeeds, we can then read any of the
      4 blocks in that sector (though only block 4 is read here)
    If the card has a 7-byte UID it is probably a Mifare
    Ultralight card, and the 4 byte pages can be read directly.
    Page 4 is read by default since this is the first 'general-
    purpose' page on the tags.
This is an example sketch for the Adafruit PN532 NFC/RFID breakout boards
This library works with the Adafruit NFC breakout
  ----> https://www.adafruit.com/products/364
Check out the links above for our tutorials and wiring diagrams
These chips use SPI to communicate, 4 required to interface
products from Adafruit!
#include <Adafruit_PN532.h>
#define SCK  (13)
#define MOSI (11)
#define SS   (10)
#define MISO (12)
Adafruit_PN532 nfc(SCK, MISO, MOSI, SS);
void setup(void) {
  Serial.begin(9600);
  Serial.println("Hello!");
  nfc.begin();
  uint32_t versiondata = nfc.getFirmwareVersion();
  if (! versiondata) {
    Serial.print("Didn't find PN53x board");
    while (1); // halt
  // Got ok data, print it out!
  Serial.print("Found chip PN5"); Serial.println((versiondata>>24) & 0xFF, HEX);
  Serial.print("Firmware ver. "); Serial.print((versiondata>>16) & 0xFF, DEC);
  Serial.print('.'); Serial.println((versiondata>>8) & 0xFF, DEC);
  // configure board to read RFID tags
  nfc.SAMConfig();
  Serial.println("Waiting for an ISO14443A Card ...");
void loop(void) {
  uint8_t success;
  uint8_t uid[] = { 0, 0, 0, 0, 0, 0, 0 };  // Buffer to store the returned UID
  uint8_t uidLength;                        // Length of the UID (4 or 7 bytes depending on ISO14443A card type)
  // Wait for an ISO14443A type cards (Mifare, etc.).  When one is found
  // 'uid' will be populated with the UID, and uidLength will indicate
  // if the uid is 4 bytes (Mifare Classic) or 7 bytes (Mifare Ultralight)
  success = nfc.readPassiveTargetID(PN532_MIFARE_ISO14443A, uid, &uidLength);
  if (success) {
    // Display some basic information about the card
    Serial.println("Found an ISO14443A card");
    Serial.print("  UID Length: ");Serial.print(uidLength, DEC);Serial.println(" bytes");
    Serial.print("  UID Value: ");
    nfc.PrintHex(uid, uidLength);
    Serial.println("");
    if (uidLength == 4)
      // We probably have a Mifare Classic card ...
      Serial.println("Seems to be a Mifare Classic card (4 byte UID)");
      // Now we need to try to authenticate it for read/write access
      // Try with the factory default KeyA: 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
      Serial.println("Trying to authenticate block 4 with default KEYA value");
      uint8_t keya[6] = { 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF };
     // Start with block 4 (the first block of sector 1) since sector 0
     // contains the manufacturer data and it's probably better just
     // to leave it alone unless you know what you're doing
      success = nfc.mifareclassic_AuthenticateBlock(uid, uidLength, 4, 0, keya);
      if (success)
        Serial.println("Sector 1 (Blocks 4..7) has been authenticated");
        uint8_t data[16]={ 'k', 'a', 'n', 'g', 'r', 'u', 'b', 'u', '.', 'c', 'o', 'm', 0, 0, 0, 0};
       Serial.println("writing");
        // If you want to write something to block 4 to test with, uncomment
      // the following line and this text should be read back in a minute
        //data = { 'a', 'd', 'a', 'f', 'r', 'u', 'i', 't', '.', 'c', 'o', 'm', 0, 0, 0, 0};
        success = nfc.mifareclassic_WriteDataBlock (4, data);
        // Try to read the contents of block 4
        success = nfc.mifareclassic_ReadDataBlock(4, data);
        if (success)
          // Data seems to have been read ... spit it out
          Serial.println("Reading Block 4:");
          nfc.PrintHexChar(data, 16);
          Serial.println("");
          // Wait a bit before reading the card again
          delay(1000);
        else
          Serial.println("Ooops ... unable to read the requested block.  Try another key?");
      else
        Serial.println("Ooops ... authentication failed: Try another key?");
    if (uidLength == 7)
      // We probably have a Mifare Ultralight card ...
      Serial.println("Seems to be a Mifare Ultralight tag (7 byte UID)");
      Serial.println("Writing operation");
       uint8_t data1[16]={ 'k', 'a', 'n', 'g', 'r', 'u', 'b', 'u', '=', 'A', 'R', 'h', '+', 0, 0, 0};
            success = nfc.mifareclassic_WriteDataBlock (4, data1);
      // Try to read the first general-purpose user page (#4)
      Serial.println("Reading page 4");
      uint8_t data[32];
      success = nfc.mifareultralight_ReadPage (4, data);
      if (success)
        nfc.PrintHexChar(data, 4);
        Serial.println("");
        delay(500);
      else
        Serial.println("Ooops ... unable to read the requested page!?");
And I foundthis C code http://code.google.com/p/nfc-tools/source/browse/trunk/libfreefare/examples/mifare-desfire-read-ndef.cfor read desfire card.But I dont know how to modify PN532.c file according to this link?
dogan
Re: adafruit shield
by dogan on Thu Dec 27, 2012 4:54 pm
Is there any recommendations ?
dogan
Re: pn532 shield
by adafruit_support_bill on Thu Dec 27, 2012 5:15 pm
Are you using the latest version of the library? viewtopic.php?f=31&t=33836&p=174406&hilit=ndef+card#p174283
Re: pn532 shield
by dogan on Thu Dec 27, 2012 7:18 pm
I'm using last version of library.Additionally I succesfully read mifare classic but I need code or tutorial for read/write to desfire ev1.
dogan
Re: pn532 shield
by adafruit on Sun Dec 30, 2012 4:28 pm
we do not have any examples for any cards other than mifare classic
