Motor Shield Adafruit and Leonardo
by Kriscox on Sat Dec 29, 2012 3:30 pm
I have an error when i compile the library AFMotor.H
It's doesn't work.
What's is the problem ?
Kriscox
Re: Motor Shield Adafruit and Leonardo
by adafruit_support_bill on Sat Dec 29, 2012 3:49 pm
Under the hood, the Leonardo is quite different from the classic Arduinos. Although it has similar pinouts, the port/pin mappings and timers are all different. This makes it incompatible with any Arduino library that uses timers or port-level I/O.
As it says in the product description:
It is probably not going to work with nearly any shields other than the proto shield.
by Kriscox on Sat Dec 29, 2012 6:19 pm
Thanks for your answer. I change my leonardo for one uno
Kriscox
by daremick on Fri Jan 04, 2013 9:15 pm
Kriscox wrote:I have an error when i compile the library AFMotor.H
It's doesn't work.
http://arduino.cc/forum/index.php/topic,140631.0.html
daremick
