Working Stepper Library for Arduino Due
Re: Working Stepper Library for Arduino Due
There is a jumper just above the 3.3v and 5v pins. Cut the small trace between the center pad and the 5v pad and bridge from the center pad to the 3.3v pad with a blob of solder.
- apurba
I am facing problem with arduino due and AF v2 shield. I have uploaded DC motor test and motor is spining in constant speed.
My requirement is to run two DC hobby motor and two hobby servo.
I have modified the shield for 3.3 v.
I have modified wire.h file to put the fux for pwm. What else I need to do?
Post the code you're using (between CODE tags please) and we'll take a look.
- apurba
Looks like it's working now in Arduino Due, I have compiled the code with Arduino IDE 1.6.3
Glad to hear it's working for you.
- ahmedsherif11
hayy i have a question about the Motor Shield V1.x . can i run 2 DC motors 12 V at 12V supply and at the same supply run a 4.8V stepper ??? and how can i do it ??? should i change my code ??? or connect something ??? PLEASE help !!!
@BANNED - Your question is not relevant to this topic. You already have started a thread for your unrelated topic. Only one thread per topic please!
- mohsan_raza
Hi All,
I am new to Arduino. I have Arduino DUE and adafruit motor shield V1.0. My problem is how to attach motor shield to Arduino? I tried google but got no answer.
The V1 motor shield is not compatible with the Due. Only the V2 shield will work with that processor.
- arjunhunter007
today i bought a arduino due and adafruit motor shield v1 , but it is not working....wat can i do to operate due with v1 library...
plz itz urgent
anyone send some suggestions or links for compatible libraries
plz itz urgent
