RGB LCD Display Temperature spec?
by OhNoItsMrBill on Mon Dec 31, 2012 7:03 pm
Is there a complete specification for the RGB LCD Display shield? I used it with a temperature data logger and then display blanks at a relatively high temperature. I was expecting typical electronics temperature range of 32 to 104deg F. However, the LCD blanked at about 45 deg F. This was even with full contrast.
Bill
OhNoItsMrBill
Re: RGB LCD Display Temperature spec?
by adafruit_support_bill on Tue Jan 01, 2013 7:44 am
The electrical characteristics of the LCD fluid vary with temperature. Typical LCD display ratings are in the 0C - 50C range.
by OhNoItsMrBill on Tue Jan 01, 2013 8:55 pm
Thanks, Looks like my battery was dead, so the the display was dropping out. Works better with full battery.
OhNoItsMrBill
by adafruit_support_bill on Wed Jan 02, 2013 7:13 am
Yea, a cold, weak battery and a cold display would be a bad combination. The display needs a higher drive voltage as the temp drops, and battery output tends to drop in the cold as well.
