DS1307 RTC with Time and TimeAlarms library
- Franklin97355
Re: DS1307 RTC with Time and TimeAlarms library
RTC and rtc are two different values. You have no declaration for rtc in your code.
- adafruit_support_rick
You've declared RTC this way:
That is, as all caps. Capitalization is significant.
You want this:
RTC_DS1307 RTC;
You want this:
time_t syncProvider() {
return RTC.now().unixtime();
- john_folsom
well I feel kinda stupid..... Thanks guys, that was exactly the problem!
- crixus_markus
hey... sir I'm making a project title interactive digital clock.,once you call time, it will response the current time.. same as the date, temperature and the alarm.. my problem is, in setting the alarm. i want to set a value particularly on the hourStart1 and minuteStart1.. through a for-loop function...? any advices ?
time_t newStart1 = AlarmHMS (hourStart1, minuteStart1, 0);
Alarm1 = Alarm.alarmRepeat(newStart1, alarmTone);
Use the Time Alarms library:
https://www.pjrc.com/teensy/td_libs_TimeAlarms.html
