DS1307 RTC with Time and TimeAlarms library
- adafruit_support_rick
Re: DS1307 RTC with Time and TimeAlarms library
Thanks for the summary!
- Tamadite
Just to complete the previous excellent summary, here you go a working case based on the example given with TimeAlarms.h
VERY IMPORTANT: Alarm.delay([ms]) is always needed by TimeAlarms.h to trigger alarms. You can set [ms] to 0 (cero) if no delay is needed.
* TimeAlarmExample.pde
* This example calls alarm functions at 8:30 am and at 5:45 pm (17:45)
* and simulates turning lights on at night and off in the morning
* A weekly timer is set for Saturdays at 8:30:30
* A timer is called every 15 seconds
* Another timer is called once only after 10 seconds
* At startup the time is set to Jan 1 2011 8:29 am
#include <Wire.h>
#include "RTClib.h"
#include <Time.h>
#include <TimeAlarms.h>
RTC_DS1307 RTC;
void setup()
Serial.begin(9600);
Wire.begin();
RTC.begin();
setSyncProvider(syncProvider);
RTC.now();
Alarm.alarmRepeat(8,30,0, MorningAlarm); // 8:30am every day
Alarm.alarmRepeat(17,45,0,EveningAlarm); // 5:45pm every day
Alarm.alarmRepeat(dowSaturday,8,30,30,WeeklyAlarm); // 8:30:30 every Saturday
Alarm.timerRepeat(15, Repeats); // timer for every 15 seconds
Alarm.timerOnce(10, OnceOnly); // called once after 10 seconds
time_t syncProvider() //this does the same thing as RTC_DS1307::get()
return RTC.now().unixtime();
void loop(){
digitalClockDisplay();
Alarm.delay(1000); // wait one second between clock display
// functions to be called when an alarm triggers:
void MorningAlarm(){
Serial.println("Alarm: - turn lights off");
void EveningAlarm(){
Serial.println("Alarm: - turn lights on");
void WeeklyAlarm(){
Serial.println("Alarm: - its Monday Morning");
void ExplicitAlarm(){
Serial.println("Alarm: - this triggers only at the given date and time");
void Repeats(){
Serial.println("15 second timer");
void OnceOnly(){
Serial.println("This timer only triggers once");
void digitalClockDisplay()
// digital clock display of the time
Serial.print("Unix time: ");
Serial.println(RTC.now().unixtime());
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.println();
void printDigits(int digits)
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
That's great! Thanks for posting!
- sachlj
This code can be used for repeat after minutes? I need to be repeated every 4 minutes cycle: start the pump with water for 1 min and 40 seconds. Then turn off the pump. I apologize for my English.
Yes. It will work with a four minute delay.
- sachlj
Thank you for answer. What is the correct syntax for the command? Start every 4 minutes, run code 1 minute and 40 seconds in order not to stop the next code.
Set a repeating timer for 4 minutes in setup:
void setup()
Alarm.timerRepeat(240, four_minute_task); // set up task to run every 4 minutes
void loop()
Alarm.delay(1); //must call Alarm.delay at least once per loop to guarantee that four_minute_task will run.
void four_minute_task()
Serial.println(F("runs every four minutes"));
- sachlj
Thank you.I try.
I wrote this code but does not work as I need. Somewhere I have a mistake. Relay starts but remains switched on and off after a set time.
/*code for Arduino MEGA 2560-*/
#include <Wire.h>
#include "RTClib.h"
#include <Time.h>
#define Relay_1 38
// #define Relay_2 40
#define RELAY_ON 1
#define RELAY_OFF 0
RTC_DS1307 RTC;
void setup()
Serial.begin(9600);
digitalWrite(Relay_1, RELAY_OFF);
// digitalWrite(Relay_2, RELAY_OFF);
pinMode(Relay_1, OUTPUT);
// pinMode(Relay_2, OUTPUT);
Wire.begin();
RTC.begin();
RTC.now();
Alarm.timerRepeat(240, pump); // set up task to run every 4 minutes
void loop(){
Alarm.delay(1); // wait one second between clock display
void pump(){
digitalWrite(Relay_1, RELAY_ON);// set the Relay ON
Serial.println("Relay - ON");
delay(10000);
digitalWrite(Relay_1, RELAY_OFF);// set the Relay OFF
Serial.println("Relay - OFF");
Please post the output from serial monitor
- sachlj
Here is the output. 2x relay is switched on and off and then turned on. I suppose for 4 minutes. Output to serial port is no even if it is set.
Your code is working for me. I reduced the alarm time to 20 seconds. I get this on Serial Monitor:
It should still work, even if your RTC is not running. However, try running the attached sketch, which will initialize your RTC:
Relay - ON
1430844228
Relay - OFF
1430844238
Relay - ON
1430844248
Relay - OFF
1430844258
Relay - ON
1430844268
Relay - OFF
1430844278
Relay - ON
1430844288
Relay - OFF
1430844298
#include <Wire.h>
#include "RTClib.h"
#include <Time.h>
#define Relay_1 38
#define RELAY_ON 1
#define RELAY_OFF 0
RTC_DS1307 RTC;
void setup()
Serial.begin(9600);
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
RTC.adjust(DateTime(__DATE__, __TIME__));
RTC.now();
Alarm.timerRepeat(20, pump); // set up task to run every 4 minutes
void loop(){
void pump(){
delay(10000);
- sachlj
Thank you. I'll try it. Also, I thought of the way to work. Can you think of how to fix the pump to be turned on for 1 minute and 40 seconds (but accurately), but they did not stop running other code? After 1 minute (simultaneously) required to run other code (read sensor values and record to mySQL). Comply with the time 1:40 is important to overflow tank that is so infused.
Just set another timer when you turn on the pump. When the timer expires, turn the pump off:
#include <Wire.h>
#include "RTClib.h"
#include <Time.h>
#define Relay_1 38
#define RELAY_ON 1
#define RELAY_OFF 0
RTC_DS1307 RTC;
void setup()
Serial.begin(9600);
Wire.begin();
RTC.begin();
RTC.now();
Alarm.timerRepeat(240, pumpOn); // set up task to run every 4 minutes
void loop(){
Alarm.delay(1);
void pumpOn(){
Alarm.timerOnce(100, pumpOff);
void pumpOff(){
- sachlj
Thank you. It's not 100% but I can not finish himself.
- john_folsom
I'm working with these libraries to trigger an automatic pet feeder and am having a problem getting it to compile correctly. After putting in the function, I get the following error -
Automated_Pet_Feeder_2.ino: In function 'time_t syncProvider()':
Automated_Pet_Feeder_2.ino:51:10: error: 'rtc' was not declared in this scope
Error compiling.
Here is the full code -
Anyone have an idea of what might be happening?
time_t syncProvider() {
return rtc.now().unixtime();
Error compiling.
//Libraries must include in this order
#include <Wire.h>
#include <RTClib.h>
#include <Time.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
RTC_DS1307 RTC;
//Create the Adafruit_MotorShield object
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
//Create the stepper motor object
//Request the Stepper motor from the Adafruit_MotorShield:
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
Serial.begin(57600);
Wire.begin();
RTC.begin();
RTC.now;
if(timeStatus()!= BANNED)
Serial.println("Unable to sync with the RTC");
else
Serial.println("RTC has set the system time");
//sets a daily alarm at 6am
Alarm.alarmRepeat(06, 00, 00, FeedMe);
//sets a daily alarm at 8pm
Alarm.alarmRepeat(20, 32, 0, FeedMe);
// Alarm.timerRepeat(15, FeedMe);
AFMS.begin();
myMotor->setSpeed(20);
DateTime now = RTC.now();
Alarm.delay(1000);
// Serial.print(now.year(), DEC);
// Serial.print('/');
// Serial.print(now.month(), DEC);
// Serial.print(now.day(), DEC);
// Serial.print(' ');
// Serial.print(now.hour(), DEC);
// Serial.print(':');
// Serial.print(now.minute(), DEC);
// Serial.print(now.second(), DEC);
// Serial.println();
//function to run when the alarm goes off
void FeedMe() {
myMotor->step(100, FORWARD, DOUBLE);
delay(3000);
myMotor->step(100, BACKWARD , DOUBLE);
