2.8" Ada TFT Shield and JOS Operating system
by badshield on Tue Jan 29, 2013 4:28 pm
Hello to the ada community!
At the moment i am trying to get the JOS Operating system runnung wit an mega 2560 and the adafruit 2.8" TFT Touch Shield.
The graphictest out of the lcdtft and the
touchscreendemo out of the touchlibrary is working so far.
I tried 2 get the Jos Operating system running:
http://thecustomgeek.com, but the following error while checking JOS_Touch_15 occured:
JOS_Touch_15.ino: In function 'void setup()':
JOS_Touch_15:138: error: 'class Adafruit_TFTLCD' has no member named 'readRegister'
Anybody got an idea what 2 do?
Thankx so far.
badshield :)
badshield
Re: 2.8" Ada TFT Shield and JOS Operating system
by adafruit_support_rick on Wed Jan 30, 2013 9:26 am
That JOS sketch was apparently written for an older version of the Adafruit_TFTLCD library. I suggest contacting the author and asking him to update his sketch.
by alternator on Mon Feb 04, 2013 11:04 pm
I just ran into the same problem. I found an older version of the Adafruit TFTLCD library here and it compiled:
https://github.com/adafruit/TFTLCD-Libr ... 931e114b58
One problem I have now is that the touch is not responding. I'm using a Arduino Duemilanove with the Adafruit 2.8" LCD shield.
alternator
by adafruit_support_rick on Tue Feb 05, 2013 10:21 am
alternator wrote:One problem I have now is that the touch is not responding.
You're using the Adafruit touch library?
Is the problem that it's not working with JOS, or that it's not working at all? What happens with the standard Adafruit example code?
