Need help with NFC shield
by kevinljxljx on Thu Feb 07, 2013 12:30 am
Hi guys. So I just got a Adafruit NFC shield today. I downloaded the library and burned the example program to my arduino Mega 1280. But it didn't work......... I connected VCC and GND (of course...), SDA and SCL to 20 and 21 port, analog 4,5 to analog 4,5 on Arduino board, Digital 2 to PWM 2 on Arduino board and RSt to RST. However, when I try to run the program, the Serial Monitor show "Hello, Didn't find PN53X board." Did I use the wrong library and wrong program or what? Can someone helps me out? Thanks!
kevinljxljx
Re: Need help with NFC shield
by adafruit_support_bill on Thu Feb 07, 2013 6:58 am
Analog 4,5 are SDA and SCL on an UNO. On the Mega, you should only connect SDA, SCL to pins 20, 21.
by kevinljxljx on Thu Feb 07, 2013 12:46 pm
Thanks, I finally figure out that I connect the wrong port. :shock:
I have some more questions that I am trying to write something to my card, but the example programs seems doesn't like to work. Can you help me out?
Finally, I am confused about NDEF cards and mifare classic cards. What's the difference between these two types of card?
kevinljxljx
by adafruit_support_bill on Thu Feb 07, 2013 1:36 pm
Can you be more specific about the problem?
NDEF support is limited at this point. There are a few threads on the forum related to this topic:
viewtopic.php?f=31&t=35489&p=175664
viewtopic.php?f=31&t=33836&p=174406&hilit=ndef#p167479
The detailed description of the differences is here:
http://www.nxp.com/documents/applicatio ... AN1304.pdf
by kevinljxljx on Thu Feb 07, 2013 5:10 pm
yeah... so I was trying to use the example program to write my email address to the card, but when I try to upload the program, the software tells me error, like what the screenshot shows.
BTW, do you have a list of what command I can use with the library? Thanks!
kevinljxljx
by adafruit_support_bill on Thu Feb 07, 2013 7:35 pm
There are three definitions of "url" in that example. You can only use one of the three, you have to comment out the other two.
by kevinljxljx on Thu Feb 07, 2013 11:56 pm
ok I get it now...I can only use one out of three....
and how about this ? I don't know where the error come from....
kevinljxljx
by adafruit_support_bill on Fri Feb 08, 2013 7:23 am
Move the array assignment up to the declaration line for data.
uint8_t data[16] = {'a', 'd', 'a',     ... etc...
