Motor Shield code question
by XtremeIN on Thu Feb 14, 2013 3:54 am
I have what I think is a simple question. I have my motor shield assembled and turning my stepper motors nicely, but in the example code the following is used:
AF_Stepper motor(48, 2);
I know the 2 calles the second motoer or M3 and M4 on the board. What is the 48?
Thank you,
Micheal
XtremeIN
Re: Motor Shield code question
by adafruit_support_bill on Thu Feb 14, 2013 7:20 am
The 48 tells the stepper library how many steps there are in a full rotation for your motor.
This number is used in speed calculations. When you specify a certain number of RPM, the library will calculate the number of steps per second it needs to generate to achieve that speed.
If you are using something other than a 48-step (1.25 degree/step) motor, you should change that number to match.
by XtremeIN on Fri Feb 15, 2013 5:30 am
Thank you very much for you quick response. I now remember reading that somewhere.....duh!
I know have another question.
I understand that I can not turn on two different stepper motors at the same time. To simulate the look and feel of both I must interlace them stepping.
for (int i=0; i<200; i++)
motor1.step(1, FORWARD, SINGLE);
motor2.step(1, FORWARD, SINGLE);
What I am trying to do is home a X and Y axis table. At power up of the table it will not know where the table is. I would like to have both the X and Y stepper motors jog until a switch is made. I can make it work by doing it one at a time, but I would relly like for both to move toghter. Right now I have this, which does one at a time:
while (digitalRead (XhomeSwitch) == HIGH)
XaxisMotor.step (1, FORWARD, DOUBLE);
while (digitalRead (YhomeSwitch) == HIGH)
YaxisMotor.step (1, FORWARD, DOUBLE);
I m just not sure which stlye loop to use or how to nest them.
Thank you,
Micheal
XtremeIN
by adafruit_support_bill on Fri Feb 15, 2013 7:15 am
Something like this should do it:
while ((digitalRead (XhomeSwitch) == HIGH) || (digitalRead (YhomeSwitch) == HIGH))
   if(digitalRead (XhomeSwitch) == HIGH)
   if(digitalRead (YhomeSwitch) == HIGH)
You should also consider the AF_Motor/AccelStepper option. See the "MultiStepper" example in the AF_Motor library.
