Play a random file from a directory (WaveShield, WaveHC)
by Vincent14 on Fri Feb 15, 2013 7:32 am
Hello, I'm french
I've put some files in a folder on my SD card. I've wrote a function using the folder name, and now my goal is to be able to select a random file then play it on the Wave Shield.
Unfortunatly, I meet a problem with my algorythm:
dir_t dirBuf;
int folderSize = 0;
while (folder.readDir(dirBuf) > 0)
   folderSize ++;
folder.rewind();
int randomFile = random(1, folderSize+1);   //random() exclude the max value
int selected = 1;      //There is at least 1 file to play
   if (selected == randomFile)
       * Now, translate the dirBuf.name (8.3 format) into
       * a char array comaptible with FatReader open() function
       * Count real characters contained in dirBuf.name:
       * 8.3 mean 8 characters for name and 3 for extension
       * if the file name is under 8 characters, some spaces are added
      int fileNameLength = 1;   //dirBuf.name does not contain the dot
      for (int i = 0; i < 11; i++) //11 because a 8.3 file name has 8+3 characters
         if (dirBuf.name[i] == ' ')
            continue;
         else
            fileNameLength++;
      char fileName[fileNameLength];
      int letters = 0;
            continue;
         if (i == 8)
            fileName[letters] = '.';
            letters++;
         fileName[letters] = dirBuf.name[i];
         letters++;
      Serial.println(sizeof(fileName)/sizeof(char));
      Serial.println(fileName);
      if (!file.open(folder, fileName))
         error("open the file has failed");
      break;
   selected++;
In the terminal, I get an error very incredible, then the size of the table is smaller than the number of characters that the variable prints! Look at this:
Searching for Serial monitor (picocom) ... /usr/bin/picocom
Guessing serial port ... /dev/ttyACM0
picocom v1.7
port is        : /dev/ttyACM0
flowcontrol    : none
baudrate is    : 9600
parity is      : none
databits are   : 8
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : no
nolock is      : yes
send_cmd is    : sz -vv
receive_cmd is : rz -vv
imap is        :
omap is        :
emap is        : crcrlf,delbs,
Terminal ready
8
R2_D.WAVR2_D    WAV
Error: open the file has failed
The file name is however "R2_D.WAV" (8 characters) but I can't understand why "R2_D WAV " is added at the end of my array?
I've tried many things, like putting a println just before and after (to see if a loop could be the reason), or making my own "for()" instead of using println on the array.
I can't understand what happening, could you help me?
Vincent14
Re: Play a random file from a directory (WaveShield, WaveHC)
by adafruit_support_bill on Fri Feb 15, 2013 7:50 am
Strings in C require a null character at the end for termination. The extra characters at the end are probably whatever is in memory following your "filename" array.
by Vincent14 on Fri Feb 15, 2013 9:34 am
I just changed the initialization of "int fileNameLength" to 2 and added "fileName[fileNameLength-1] = NULL;" after the second "for", and it has worked! Thanks very much!
Is there a better way to do that, according to you?
Vincent14
by adafruit_support_bill on Fri Feb 15, 2013 9:44 am
Not really. Your solution is the usual way to do it. :D
