Waveshield/WaveHC seamless/gapless loop? (again)
by xl97 on Fri Feb 15, 2013 1:33 pm
Hey gang--
been playing with another lib posted on the Arduino forums.. (SimpleSDAudio)
that does PWM audio output..etc..
I dont know about whats going on 'under the hood' (so to speak).... but it has a 'working' function.. that seems to keep feeding the cache with the next chunk of data for audio output.....
This has allowed me to get a seamless/gapless loop (no clicks, no pops, no overlay).. a nice, true 'loop'...
This has got me back to thinking about the WaveShield/WaveHC lib.. and the differences (or possible tweaks?) between the two libs... and how to get a better (seamless/gapless) loop from the WaveHC lib??
Is this a hardware problem/restriction? or code in way the lib was created?
I'd be very interested/curious if anybody has achieved this with the WaveHC lib? and if so..how? what tweaks to lib did you have to do? I have (another) project that could benefit from a better 'loop' playback than I currently get with the WaveHC lib..
:mrgreen:
xl97
Re: Waveshield/WaveHC seamless/gapless loop? (again)
by xl97 on Tue Feb 19, 2013 2:43 pm
surely someone has tried to play a seamless/gapless loop with their Waveshield before....no?
maybe the WaveHC lib was -not- designed for this type of functionality?.. and only for simple triggered audio play back? (no looping)
I dont think having a snippet of code/function that acts as a 'watch dog' for if wav.iSplaying() (or whatever) really 'works' for making the loop seamless/gapless..
(even though the audio file itself is created to be looped seamlessly (zero cross fade..etc))
staff/support?
members? :)
thanks!
xl97
by xl97 on Tue Apr 02, 2013 9:37 am
lets do 'da bump! :)
xl97
by ripanddestroy on Mon Aug 26, 2013 7:52 pm
I've been searching posts re: seamless looping and I came across a couple of your threads. Did you ever get anywhere with the library you preferred to use? I am getting ready to build a white noise/sleep machine using a wave shield and was looking for some known working code for a seamless loop.
Thanks,
Ripanddestroy
ripanddestroy
by xl97 on Mon Aug 26, 2013 8:24 pm
no.. "I" havent..
but I haven been a bit busy on other projects..
I believe there was a reply HERE by a staff member who says it 'works for him'... using his supplied audio file..
(but not the one I had tested with, as well as sent to the author of the library, and has been used in 'many' other props/boards that play it seamlessly)
here is the thread:
viewtopic.php?f=31&t=40263&p=200349&hilit=gapless#p200349
again.. i can hear/notice when the file starts over using the Waveshield.. but not other proprietary soundboards..
havent been back on that project in a while.. could figure out how to get seamless playback..s o I shelved it for the time being.
xl97
by Kirk Patrick on Mon Mar 03, 2014 3:35 am
It's unfortunate, I have just bought a whole bunch of the wav Shields with the belief that it can loop seamlessly and it doesn't seem to do this.
I have tested it out with numerous different tones and different ways of changing the sample rate etc to see if the problem is in that.
It's really frustrating.
I was mainly using the example files provided here
http://learn.adafruit.com/adafruit-wave ... o/examples
and none of them seem to loop it flawlessly although they do seem to say that it will.
Any help ?
Kirk Patrick
by Kirk Patrick on Mon Mar 03, 2014 3:37 am
oh, and i should also add that the samples all loop flawlessly in Ableton and Audacity but NOT in the Wav Shield.
If I find out otherwise I will come back and let you know.
Kirk Patrick
by xl97 on Mon Mar 03, 2014 9:16 am
Kirk Patrick wrote:oh, and i should also add that the samples all loop flawlessly in Ableton and Audacity but NOT in the Wav Shield.
please do..
I have asked/posted myself..
and while many people 'say' it will.. I havent actually found an example that 'will'...
there was one thread around here..where a mod/member posted it works...etc.. (with some file sample her had/posted)... but I never got back around to playing with this..
I believe it will take some serious re-working of the WaveHC library or something..
post back if you find anything!
xl97
