AFMotor MultiStepper
by rshunter on Sun Feb 17, 2013 10:05 am
> When I try to verify the the code for AFMotor_MultiStepper or AFMotor_ConstantSpeed I get the > following errors.
> It is running from Sketchbook.
> /home/rsh/Arduino/arduino-1.0.3/libraries/AFmotor/AFMotor.cpp:136:5: error:
> #error "This chip is not supported!"
> /home/rsh/Arduino/arduino-1.0.3/libraries/AFmotor/AFMotor.cpp:173:5: error:
> /home/rsh/Arduino/arduino-1.0.3/libraries/AFmotor/AFMotor.cpp:205:5: error:
> /home/rsh/Arduino/arduino-1.0.3/libraries/AFmotor/AFMotor.cpp:226:5: error:
> /home/rsh/Arduino/arduino-1.0.3/libraries/AFmotor/AFMotor.cpp:259:5: error:
> /home/rsh/Arduino/arduino-1.0.3/libraries/AFmotor/AFMotor.cpp:279:5: error:
> /home/rsh/Arduino/arduino-1.0.3/libraries/AFmotor/AFMotor.cpp:314:5: error:
> /home/rsh/Arduino/arduino-1.0.3/libraries/AFmotor/AFMotor.cpp:334:5: error:
> /home/rsh/Arduino/arduino-1.0.3/libraries/AFmotor/AFMotor.cpp: In
> constructor ‘AF_Stepper::AF_Stepper(uint16_t, uint8_t)’:
> /home/rsh/Arduino/arduino-1.0.3/libraries/AFmotor/AFMotor.cpp:438: error:
> ‘CS20’ was not declared in this scope
> I am using a Leonardo board running on Ubuntu. The LCD with backpack runs OK
> (after some help from you).
> Thanks for your help.
> Ron Hunter (rshunter@sympatico.ca)
rshunter
Re: AFMotor MultiStepper
by adafruit_support_rick on Sun Feb 17, 2013 5:36 pm
Unfortunately, it means that the Leonardo cannot be used with the AFMotor library. The Leonardo uses an ATmega32U4 chip, which has a different arrangement of timers and pins than the ATmega328 used in the UNO. The AFMotor library has not been written to work with the 32U4.
by haasebert on Thu Mar 14, 2013 9:08 pm
Is anyone working on porting a library for the Leonardo?
haasebert
by adafruit_support_rick on Fri Mar 15, 2013 11:46 am
We are in the process of porting our libraries to Leonardo and Due. Offhand, I can't say whether or not the motor shield is even compatible with Leonardo, due to the different pin mappings for the timers. I'll have to investigate that.
by adafruit_support_rick on Sun Mar 17, 2013 10:30 am
I just checked the timer pinouts, and it looks like it ought to be possible to port the library to Leonardo. No time frame for that, however.
by displaced1980 on Fri May 10, 2013 4:20 pm
Michael Margolis has produced a version of the AFMotor library to accompany his book on using the Arduino for robotics.
The publisher of the book has made the library available as part of this download:
http://examples.oreilly.com/0636920028024/
displaced1980
