RGB Shield Issue
Re: RGB Shield Issue
by adafruit_support_rick on Fri Mar 01, 2013 4:14 pm
Ohhh! You want the buttons to toggle! Your original code treated them as momentaries, so I went with that.
First, yes, readButtons returns the current state of all buttons. It simply reads the current state of the MCP23017 and pulls out the button bits. This is typical behavior for this sort of thing. Usually, you would maintain a local copy of the last state read, and perform an exclusive-or with the value returned by readButtons to determine which buttons, if any, changed state. Then you'd react to the new state of the changed buttons.
For toggles, you can simply read the state of your output pin. If it reads as HIGH, then your relay is enabled, and you can turn it off. And vice-versa.
  if (digitalRead(buttonPin) == HIGH)  // button is pressed
      digitalWrite(ledPin, !digitalRead(ledPin));        // toggle current output state - if HIGH, write LOW. if LOW, write HIGH
Put a delay(250); at the bottom of the loop so you don't cycle through too quickly
Last edited by adafruit_support_rick on Fri Mar 01, 2013 4:18 pm, edited 1 time in total.
Reason: changed '~' to '!'. '~' doesn't work...oops...
by Bigjeep093 on Fri Mar 01, 2013 6:56 pm
that works perfectly.
thanks!
and I have to ask. is there a way to do that WITH the buttons that are on the Adafruit RGB LCD Shield? The ones that are predefined? UP, DOWN, LEFT, RIGHT, SELECT?
that would free up a few pins.
Bigjeep093
by adafruit_support_rick on Fri Mar 01, 2013 11:59 pm
Sure - I think you already had it right before:
  uint8_t buttons = lcd.readButtons();
  if (buttons) {  //if any buttons are pressed
    if (buttons & BUTTON_LEFT)    // Button LEFT is PUMP 1, relay 2
        digitalWrite(leftRelayPin, !digitalRead(leftRelayPin)); // toggle relay
    …etc …
