Hello there
I have some problems with my RFID-Shield. I got it yesterday, did all the soldering, downloaded the library from Github, installed it and so on . I used the readMifare example, opend the serial monitor and got the message " didn't find the PN53x board".
So i checked my solerding twice, downloaded the library again, but the result is still the same.
I rode all of the posts in this forum, but i cant figure out why it isnt working.
The busy and the power led are on permanent. Doesn't matter if i put an card at the shield or not.
I am using an Mega 2560 R3. The tutorial says that it should be no problem with the R3.
So I hope someone can help me with this..
Thanks from Germany and sorry for my english
Trouble with the PN 532 RFID Shield
- Attachments
- 2013-02-28 17.53.19.jpg (642.42 KiB) Viewed 314 times
Re: Trouble with the PN 532 RFID Shield
And more photos
- Attachments
- The scratches betwin the two pins happend after 5 hours of cursing.... Oh there are 20 kOhms betwin this two pins, that must be the problem.... Shame on me
- 2013-02-28 17.53.04.jpg (646.94 KiB) Viewed 313 times
You solder joints look good, but they are on the wrong side. Installed that way, the header pins may not be long enough to make solid contact. They should be installed from the bottom side and soldered on the top as below.
- Attachments
- 2013_02_28_IMG_1310-1024-400.jpg (14.81 KiB) Viewed 312 times
