I have the same motorshield from adafruit:
For now the motor shield can control up to 4 DC motors, but I need to control two more DC motors. As I know the shield is using 4 PWM signals from 4 out of 6 PWM output pins from the Arduino Uno. Is there anyway we can use the other 2 remaining PWM to control 2 motors using an additional H-bridge circuit?
MotorShield with PWM
- adafruit_support_bill
Re: MotorShield with PWM
There are a couple of approaches to this:
If you do not need direction control for some motors, those motors can be controlled with just a PWM pin and a transistor.
If you do need both direction and speed on all motors, you could hook up another H-bridge chip with some of the unused pins. Or you could look into some of the serial motor control modules from Pololu.
Which PWM pins on the Arduino will connect to the Servo pins on the shield? Are they pin 9 and 10?
Yes. 9 & 10 are the servo pins.
Great, I am using L293d H-Bridge. 2 PWM signals from the Servo will go to pin 1(EN) and Motor Logic 2A (pin 7), I still need one digital pin which will go to Motor Logic 1A (pin 2). I guess I can use pin 4,7,8 or 12 from the Arduino, but I don't know how they are connected to the shield. In other words, I want to know which pins on the shield are connected to pin 4,7,8,12 on the Arduino?!
It's in the FAQ: http://learn.adafruit.com/adafruit-motor-shield/faqIn other words, I want to know which pins on the shield are connected to pin 4,7,8,12 on the Arduino?!
Hi:
Would it be correct to assume that all motors, DC and Stepper, must use the save voltage? For instance I couldn't use a 24 V power supply and a 24 volt motor and a 6 volt motor?
Or is there a way one could do this?
Z
Z
@Zenock: All would need to use the same voltage.
Could I cut the lead to PIN 8 on one of the chips and wire in a voltage regulator?
Also, If I understand correctly, the servos runs off 5 V even if I'm running the motors off 24 volts? Is this correct?
Yes. That is possible.Could I cut the lead to PIN 8 on one of the chips and wire in a voltage regulator?
Normally true. Although a separate supply for servos is possible as described in the FAQ: http://forums.adafruit.com/viewtopic.php?f=31&t=26873Also, If I understand correctly, the servos runs off 5 V even if I'm running the motors off 24 volts? Is this correct?
Thank you so much. You are AWESOME.
