Unexepected PWM frequency at 250Hz
by joemcder on Tue Mar 12, 2013 7:28 pm
I have an Adafruit motor shield attached to a UNO and a pair of small DC motors. When I run a modified version of Adafruit's Motor test the motors cycle speed up/down and forward/reverse as expected.
BUT an oscilloscope trace shows a slow PWM frequency of 250Hz! I have included several trace screen shots showing PWM output on pins 11 and 3. I also attached a scope trace of the Arduino/Shield on pin 11 and a another independent Arduino running analogWrite() on its own pin 10. analogWrite() produces 500Hz as expected.
I attached clips of Scope traces which come from Digilent's Analog Discovery, a very nice gadget.
I also attached my sketch. I'm puzzled.
By the way, the robot using the motors has expressed indifference to the PWM frequency.
He just wants his battery charged :)
Joe
// similar to Adafruit example
#include <AFMotor.h>
#define blinker  13
AF_DCMotor motor1(1, MOTOR12_8KHZ);
AF_DCMotor motor2(2);  // default = MOTOR12_1KHZ
  Serial.begin(115200);
  Serial.println("Motor test!");
  pinMode(blinker, OUTPUT);
  // turn on motor
  motor1.setSpeed(200);
  motor1.run(RELEASE);
  delay(500);
  motor2.setSpeed(200);
  motor2.run(RELEASE);
  uint8_t i;
  runCycles(&motor1);  //passing object by reference &
  runCycles(&motor2);
  Serial.println("Complete!");
  digitalWrite(blinker, HIGH);
  delay(500);
  digitalWrite(blinker, LOW);
  delay(500);
void runCycles(AF_DCMotor *pmotor)
  Serial.print("Forward Up");
  cycleMotorUp(pmotor, FORWARD);
  delay(2000);
  Serial.println(" Forward Down!");
  cycleMotorDown(pmotor, FORWARD);
  Serial.print("Reverse Up!");
  cycleMotorUp(pmotor, BACKWARD);
  delay(2000);
  Serial.println("  Reverse Down!");
  cycleMotorDown(pmotor, BACKWARD);
void cycleMotorUp(AF_DCMotor *motor, uint8_t direction)
  int i;
  motor->run(direction);
  for (i=0; i<255; i++) {
    motor->setSpeed(i);
    delay(10);
void cycleMotorDown(AF_DCMotor *motor, uint8_t direction)
  int i;
  for (i=255; i!=0; i--) {
    motor->setSpeed(i);
    delay(10);
Last edited by adafruit_support_rick on Wed Mar 13, 2013 8:49 pm, edited 1 time in total.
Reason: please use [CODE] tags
joemcder
Re: Unexepected PWM frequency at 250Hz
by adafruit_support_bill on Wed Mar 13, 2013 6:04 am
Hmmm. I'll have to check into that...
