Wave Shield Error
Wave Shield Error
by warcow on Wed Mar 13, 2013 12:18 am
I finished assembling my Wave shield but when I try to verify and upload the code I get errors. I get the errors when just verifying the code. So I don't think anything is wrong with my circuit. It should pass the compile verification. In fact any of the Wave shield example sketches I try I get errors compiling. I have uploaded other sketches to the board not related to the wave shield and they compile and upload just fine.
I just want the wave shield to play the one song on my SD Card in a continuous loop. Nothing complicated.
Here is the sketch I got when I downloaded the most up to date version of the wavehc Library. It is the one named daphc.pde
I just copied and pasted the code into the code editor window of the arduino IDE
 * This example plays every .WAV file it finds on the SD card in a loop
#include <WaveHC.h>
#include <WaveUtil.h>
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the volumes root directory
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
uint8_t dirLevel; // indent level for file/dir names    (for prettyprinting)
dir_t dirBuf;     // buffer for directory reads
 * Define macro to put error messages in flash memory
#define error(msg) error_P(PSTR(msg))
// Function definitions (we define them here, but the code is below)
void play(FatReader &dir);
//////////////////////////////////// SETUP
  Serial.begin(9600);           // set up Serial library at 9600 bps for debugging
  putstring_nl("\nWave test!");  // say we woke up!
  putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
  Serial.println(FreeRam());
  //  if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    error("Card init. failed!");  // Something went wrong, lets print out why
  // enable optimize read - some cards may timeout. Disable if you're having problems
  card.partialBlockRead(true);
  // Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {   // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                           // we found one, lets bail
  if (part == 5) {                     // if we ended up not finding one  :(
    error("No valid FAT partition!");  // Something went wrong, lets print out why
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(), DEC);     // FAT16 or FAT32?
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    error("Can't open root dir!");      // Something went wrong,
  // Whew! We got past the tough parts.
  putstring_nl("Files found (* = fragmented):");
  // Print out all of the files in all the directories.
  root.ls(LS_R | LS_FLAG_FRAGMENTED);
//////////////////////////////////// LOOP
  root.rewind();
  play(root);
/////////////////////////////////// HELPERS
 * print error message and halt
void error_P(const char *str) {
  PgmPrint("Error: ");
  SerialPrint_P(str);
  sdErrorCheck();
  while(1);
 * print error message and halt if SD I/O error, great for debugging!
void sdErrorCheck(void) {
  if (!card.errorCode()) return;
  PgmPrint("\r\nSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  PgmPrint(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
 * play recursively - possible stack overflow if subdirectories too nested
void play(FatReader &dir) {
  FatReader file;
  while (dir.readDir(dirBuf) > 0) {    // Read every file in the directory one at a time
    // Skip it if not a subdirectory and not a .WAV file
    if (!DIR_IS_SUBDIR(dirBuf)
         && strncmp_P((char *)&dirBuf.name[8], PSTR("WAV"), 3)) {
      continue;
    Serial.println();            // clear out a new line
    for (uint8_t i = 0; i < dirLevel; i++) {
       Serial.write(' ');       // this is for prettyprinting, put spaces in front
    if (!file.open(vol, dirBuf)) {        // open the file in the directory
      error("file.open failed");          // something went wrong
    if (file.isDir()) {                   // check if we opened a new directory
      putstring("Subdir: ");
      printEntryName(dirBuf);
      Serial.println();
      dirLevel += 2;                      // add more spaces
      // play files in subdirectory
      play(file);                         // recursive!
      dirLevel -= 2;
    else {
      // Aha! we found a file that isnt a directory
      putstring("Playing ");
      printEntryName(dirBuf);              // print it out
      if (!wave.create(file)) {            // Figure out, is it a WAV proper?
        putstring(" Not a valid WAV");     // ok skip it
      } else {
        Serial.println();                  // Hooray it IS a WAV proper!
        wave.play();                       // make some noise!
        uint8_t n = 0;
        while (wave.isplaying) {// playing occurs in interrupts, so we print dots in realtime
          putstring(".");
          if (!(++n % 32))Serial.println();
          delay(100);
        sdErrorCheck();                    // everything OK?
        // if (wave.errors)Serial.println(wave.errors);     // wave decoding errors
And here is the error's I get:
daphc.pde:-1: error: variable or field 'play' declared void
daphc.pde:-1: error: 'FatReader' was not declared in this scope
daphc.pde:-1: error: 'dir' was not declared in this scope
daphc.pde:-1: error: 'SdReader' does not name a type
daphc.pde:-1: error: 'FatVolume' does not name a type
daphc.pde:-1: error: 'FatReader' does not name a type
daphc.pde:-1: error: 'WaveHC' does not name a type
daphc.pde:-1: error: 'dir_t' does not name a type
daphc.cpp: In function 'void setup()':
daphc.pde:-1: error: 'putstring_nl' was not declared in this scope
daphc.pde:-1: error: 'putstring' was not declared in this scope
daphc.pde:-1: error: 'FreeRam' was not declared in this scope
daphc.pde:-1: error: 'card' was not declared in this scope
daphc.pde:-1: error: 'vol' was not declared in this scope
daphc.pde:-1: error: 'root' was not declared in this scope
daphc.pde:-1: error: 'LS_R' was not declared in this scope
daphc.pde:-1: error: 'LS_FLAG_FRAGMENTED' was not declared in this scope
daphc.cpp: In function 'void loop()':
daphc.pde:-1: error: 'play' was not declared in this scope
daphc.cpp: In function 'void error_P(const char*)':
daphc.pde:-1: error: 'PgmPrint' was not declared in this scope
daphc.pde:-1: error: 'SerialPrint_P' was not declared in this scope
daphc.cpp: In function 'void sdErrorCheck()':
daphc.cpp: At global scope:
Any help would be greatly appriciated
Warcow
warcow
Re: Wave Shield Error
by adafruit_support_mike on Wed Mar 13, 2013 2:09 am
It looks like the compiler can't find the WaveHC.h and WaveUtil.h headers.
If you launch the Arduino IDE, click on the 'Sketch' menu then select the 'Import Library...' item, do you see an item at the bottom of the popup menu named 'wavehc20110919'? If not, check to make sure the library is in the right place: inside a folder named 'libraries' in your sketchbook folder.
by wiremanflash on Thu Mar 14, 2013 11:47 pm
details, details, details...
I downloaded the file wavehc20110919.zip and installed it and imported it correctly and have WaveHC listed as opposed to the answer given just above. That's 8 characters different, so I think WaveHC is what you should be seeing in your directory structure ("...\libraries\WaveHC\..") and
Arduino 1.0.4 > Sketch > Import Library > (pulldown list)
IDE GUI command structure.
wiremanflash
by adafruit_support_mike on Fri Mar 15, 2013 12:17 am
You're right.. 'WaveHC' is the official name for the folder.
The name that appears in the menu doesn't have any effect on the Arduino IDE's ability to import libraries though. I just renamed the folder FooBar, restarted the IDE, did an import, and got exactly the right set of #includes.
The important thing is that the headers are in an immediate sub-folder of 'libraries' in the sketchbook folder. If not, the IDE doesn't know where to look.
by wiremanflash on Sat Mar 16, 2013 12:44 am
So all the headers in your accessible libraries need unique names because their library name or folder name is only organizational for the user?
wiremanflash
by adafruit_support_bill on Sat Mar 16, 2013 5:42 am
That is right. At startup, the IDE scans the top-level library folders looking for headers and building a list. If you have duplicate headers you will likely have compile problems.
