Adafruit xbee adapter v1.1 to send and receive data
by Umar Khalid on Wed Mar 13, 2013 10:01 pm
I am using xbee series 1 with adafruit xbee adapter v1.1. I have connected one adapter to the computer and other one is connected to Arduino Leonardo. When I use Arduino Serial Monitor to send data (“cool”), I can see it in x-ctu terminal as shown in the image below. But when I try to use x-ctu terminal to transmit data like ”writehere”. I cannot see anything in the serial monitor of the Arduino. I am using following code. Please can you help?
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
void setup()  {
  pinMode(13, OUTPUT);
  Serial.begin(9600);
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("Hello, world?");
void loop()                     // run over and over again
  if (mySerial.available()) {
      Serial.print((char)mySerial.read());
  if (Serial.available()) {
      mySerial.print((char)Serial.read());
  delay(100);
typing data from Arduino Serial monitor to send it to Xbee connected to PC
Data received by xbee connected to the PC from Arduino Serial Monitor
Trying to send data from PC Xbee to Arduino but Arduino do not receive anything on serial monitor
Umar Khalid
Re: Adafruit xbee adapter v1.1 to send and receive data
by adafruit_support_bill on Thu Mar 14, 2013 6:24 am
How do you have the adapters connected to the computer and Leonardo? A photo(s) would be good.
Do you get the same behavior if you swap modules/adapters?
by Umar Khalid on Thu Mar 14, 2013 8:58 am
Yes I get the same behaviour when I switch the xbee modules. On the PC side I am using “USB XBee Adapter” and here is the photo of how I have connected Arduino to xbee module.
Arduino xbee adapter connection
arduino with xbee.jpg (872.93 KiB) Viewed 536 times
Umar Khalid
by adafruit_support_bill on Thu Mar 14, 2013 9:09 am
The wiring looks right, and if swapping modules doesn't change things then the modules themselves are OK. Post photos of the front and back of the adapter (module removed) and we'll check over the assembly.
by Umar Khalid on Thu Mar 14, 2013 9:18 am
Please have a look at the front and back photo of the module.
FRONT OF THE module
back of the module
Umar Khalid
by adafruit_support_bill on Thu Mar 14, 2013 10:28 am
Assembly looks good. But the solder joint on the Tx wire (pink) looks like a cold joint. Touch that up and see if that helps.
by Umar Khalid on Thu Mar 14, 2013 10:48 am
I tried soldering the pink wire again but it does not work. when I send data from PC red led "turns on" on the adapter connected to arduino but I can not see anything on the serial monitor. I think may be the code I am using is not compatible with arduino Leonardo.
Umar Khalid
by adafruit_support_bill on Thu Mar 14, 2013 11:00 am
Aha - the Leonardo! That is likely your problem. You should be able to make it work on a different set of pins.
http://arduino.cc/en/Reference/SoftwareSerial
Not all pins on the Leonardo support change interrupts, so only the following can be used for RX: 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
by Umar Khalid on Thu Mar 14, 2013 11:10 am
Thanks a lot. Now it is working!!!!!!!!!!!!!!!!! Adafruit products and customer support are the best in the world!!!!! Thanks thanks and thanks a lot again! :D :D :D :D
Umar Khalid
