How to use pair of adafruit GPS and Adafruit xbee adapter with xbees
by Umar Khalid on Sat Mar 16, 2013 11:45 am
Please can you help me merge these 2 codes together because I tried to merge these but couldn’t get the desired results?
Basically I am using one Arduino as transmitter to send latitude and longitude data from one Arduino to another wirelessly. From transmitter I am outputting data in this format: 12223,123232. Longitude and latitude separated by coma. The code below saves these values into an array I want to merge this code with the gps code. So that I can add the value from transmitter to the value I have from gps which is connected to Arduino which is acting as receiver.
#include <SoftwareSerial.h>
SoftwareSerial xbee(8, 9);
void setup()  {
  xbee.begin(9600);
void loop()                     // run over and over again
      const int NUMBER_OF_FIELDS = 2; // how many comma-separated fields we expect
      int fieldIndex = 0; // the current field being received
      double values[NUMBER_OF_FIELDS]; // array holding values for all the fields
      if (xbee.available()) {
        for(fieldIndex = 0; fieldIndex < 2; fieldIndex ++)
          values[fieldIndex] = xbee.parseFloat(); // get a numeric value
        Serial.println(values[0],7);
        Serial.println(values[1],7);
        fieldIndex = 0; // ready to start over
  if (Serial.available()) {
      xbee.print((char)Serial.read());
  delay(100);
 #include <Adafruit_GPS.h>
SoftwareSerial mySerial(10, 11);
Adafruit_GPS GPS(&mySerial);
#define GPSECHO  false
void setup()
  Serial.begin(115200);
  delay(5000);
  GPS.begin(9600);
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
  GPS.sendCommand(PGCMD_ANTENNA);
  delay(1000);
  mySerial.println(PMTK_Q_RELEASE);
uint32_t timer = millis();
void loop()
  char c = GPS.read();
  if ((c) && (GPSECHO))
    Serial.write(c);
  if (GPS.newNMEAreceived()) {
    if (!GPS.parse(GPS.lastNMEA()))   /
      return;
  if (timer > millis())  timer = millis();
  if (millis() - timer > 2000) {
    timer = millis(); /
    if (GPS.fix) {
      float new_lat = GPS.latitude + value[0];  // this is how I want to use array to add the 2 values
      float new_long = GPS.longitude + value[1];
      Serial.print("Location: ");
      Serial.print(new_long, 4); Serial.print(GPS.lon);
      Serial.print(", ");
      Serial.print(new_lat, 4); Serial.println(GPS.lat);
Umar Khalid
Re: How to use pair of adafruit GPS and Adafruit xbee adapter with xbees
by adafruit_support_bill on Sun Mar 17, 2013 7:46 am
Maybe if you post your merged code and tell us what didn't work.
by Umar Khalid on Sun Mar 17, 2013 10:24 am
This is the combined code but this does not show added value on the serial monitor after the gps achieves a fix.
void setup()
  delay(5000);
  GPS.begin(9600);
  xbee.begin(9600);
  delay(1000);
void loop()
    Serial.write(c);
      return;
    timer = millis();
    if (GPS.fix) {
      float new_lat = GPS.latitude + values[0];  // this is how I want to use array to add the 2 values
      float new_long = GPS.longitude + values[1];
      Serial.print(", ");
Umar Khalid
by adafruit_support_bill on Sun Mar 17, 2013 11:18 am
If you are using software serial on multiple ports, only one can be used for receive at a time. http://arduino.cc/en/Reference/SoftwareSerial
You can use the "listen()" function to switch between them: http://arduino.cc/en/Reference/SoftwareSerialListen
But in your case, you will may lose some data in the process. To do what you want, you probably will require an Arduino with 2 hardware serial ports such as the Mega.
