Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
Wave Shield- Uploaded daphc.pde successfully, but no sound/no error msg's
by porrick on Sun Mar 17, 2013 10:47 pm
Hi-
I just mounted the v1.1 Wave Shield onto the Freeduino board that I put together in one of the famous NYC Resistor classes :) I then did the following:
1) formatted 2GB SD card using the format utility recommended on the Ada site
2) uploaded one of the 16khz sample WAV files recommended by the Ada site to the SD card
3) put the SD card in the Wave Shield's SD card holder
4) plugged in a pair of computer speakers to the Wave Shield (also tried over-the-ear headphones)
5) plugged in the USB cord to the Freeduino board
6) successfully uploaded the daphc.pde and the SdReadTest.pde sketch via USB cord
Neither of the sketches produce anything. No sound is coming out of the speakers/headphones and no messages (error or otherwise) are displayed in the Arduino software. I'm using Arduino software v1.0.4 which is set to Board: Arduino Duemilanove w/ ATmega328. I've confirmed that the Freeduino runs the Blink example sketch flawlessly.
Any ideas on what might be wrong? I've attached pictures- please let me know what else I can provide.
Does the Wave Shield require more power than it's currently getting from just the USB cord?
Thanks in advance for all help!
20130317_223724 (Small).jpg (55.75 KiB) Viewed 630 times
20130317_223700 (Small).jpg (59.14 KiB) Viewed 630 times
20130317_223655 (Small).jpg (61.18 KiB) Viewed 630 times
porrick
Re: Wave Shield- Uploaded daphc.pde successfully, but no sound/no error msg's
by pburgess on Mon Mar 18, 2013 12:27 am
Looks like some potential cold solder joints -- especially that middle-ish pin on the SD card holder, and pin 13 on the shield looks a little iffy as well. Remove the shield from the Arduino and go over each connection with a soldering iron, making sure both the pad and component are heated sufficiently for the solder to flow.
pburgess
by porrick on Mon Mar 18, 2013 12:12 pm
Thank you, pburgess- I'll resolder all suspect joints.
BTW- those white wires were made by stripping the breadboard wires that came from Ada [https://www.adafruit.com/products/153]- are these sufficient?
porrick
by pburgess on Mon Mar 18, 2013 1:08 pm
Yeah, the breadboard wires should be fine. The soldering at the ends does look a little haphazard, but as long as there's no solder bridges or frayed bits making contact (do you have a multimeter to check with?), they'll do the job.
pburgess
by porrick on Mon Mar 18, 2013 2:06 pm
pburgess- thanks- I'll inspect for bridges/frayed ends. I do have a multimeter- however, I've never used one :P I'll Google how to do so unless you have any recommended resources. (Thanks for your prompt replies!)
porrick
by pburgess on Mon Mar 18, 2013 6:44 pm
If it has a continuity tester mode (beeps when the probes are touched), that's what you want. Then just touch adjacent pairs of pads on the board. If there's a short between them, it'll let you know. Beeep!
If there's no specific beepy mode for this, you can just watch the display...the value will be zero (or nearly zero) if a short.
pburgess
by adafruit_support_rick on Mon Mar 18, 2013 7:05 pm
porrick wrote:I do have a multimeter- however, I've never used one I'll Google how to do so unless you have any recommended resources.
It just so happens that we have a Guide To Multimeters on the Adafruit Learning System!
by porrick on Mon Mar 18, 2013 11:54 pm
pburgess/ driverblock- Thank you so much for your help- it's playing the WAV file now! All I did was resolder some of the joints and voila!
Time to have some fun with my new working Wave Shield- I'll see you around the Forum!
Thanks again,
porrick
porrick
by porrick on Wed Mar 20, 2013 12:57 am
Just added 2 buttons to a breadboard which is connected to the Wave Shield- ck out the YOUTUBE vid! https://www.youtube.com/watch?v=AorCL8IYROk
Thanks again, guys!
porrick
by adafruit_support_rick on Wed Mar 20, 2013 10:27 am
Nice! You'll soon be tapping away like Futureman :D
by porrick on Thu Mar 21, 2013 4:13 pm
Haha- funky!
porrick
