Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
Motor shield does not work
by elranon on Tue Mar 19, 2013 5:02 am
Hello, and sorry for my bad english, but i need help.
I have arduino mega, and ladyada's motor shield v1.0(http://ladyada.net/make/mshield/) and i want connect 4 DC motors(http://www.dfrobot.com/index.php?route=product/product&path=47_110&product_id=100#.UUOuh1d42lu).
Mega powered by USB or 9v jack, Shield powered by 5xAAA battery. I want test one motor, wired him to M1 terminal on motor shield. Then i run typical code for test:
#include <AFMotor.h>
AF_DCMotor motor(1);
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Motor test!");
  motor.setSpeed(200);     // set the speed to 200/255
  Serial.print("tick");
  motor.run(FORWARD);      // turn it on going forward
  delay(10000);
  Serial.print("tock");
  motor.run(BACKWARD);     // the other way
  delay(10000);
  Serial.print("tack");
  motor.run(RELEASE);      // stopped
  delay(1000);
but motor goes not work. When i connect motor directly to battery module, he work.
But when motor connected to shield, he does not work, but sometimes it makes a noise. I use the voltmeter to test a voltage. On the shield's ext_pwr 8V, on the unplugged terminals 6v, but when i plug in motors - voltage drops to 0. Why voltage drops when i connect the motor? I tried to connect a new batteries, and increase the number up to 8 pieces(AAx8), but no effect. May be my shield has broken?
Please help me fix this trouble...
elranon
Re: Motor shield does not work
by adafruit_support_bill on Tue Mar 19, 2013 5:06 am
Post photos of the front & back of the shield and we'll check your assembly.
by elranon on Tue Mar 19, 2013 5:25 am
I posted front photo, and later i'll post back photo.
Thnx
elranon
by adafruit_support_bill on Tue Mar 19, 2013 5:33 am
Where did you purchase this shield? It looks like a very old version.
What color is the power led on the front? It looks white in the photo.
by elranon on Tue Mar 19, 2013 5:37 am
On ebay
Power led - green color. Sorry, it's a bad photo, on the smartphone
elranon
by elranon on Tue Mar 19, 2013 5:41 am
May be this old version is incompatible with Arduino Mega?
elranon
by adafruit_support_bill on Tue Mar 19, 2013 5:42 am
It looks like you got a copy of one of our older designs. Can you post a link to the eBay seller?
by elranon on Tue Mar 19, 2013 6:02 am
I'm sorry, I bought it in the middle of 2012, and am not sure I can find a link to a specific seller. I will look.
and what do you think about my problem? Do you think, the shield is bad?
elranon
by adafruit_support_bill on Tue Mar 19, 2013 6:14 am
Considering that it came from eBay, is an obsolete design and appears to have non-standard parts, I believe what you have is a counterfeit board. You should contact the seller for a refund.
