Hi. I assembled a motorshield and everything worked ok using a stepper motor (the $14 one
you guys sell) and the method where the power comes from the arduino and the jumper is
closed (using a 9V in). then i tried powering via the EXT_PWR connector, paying what i
thought was close attention to the polarity. perhaps i didn't though because now i get no
motor turning. measuring the DC output on the M3 and M4 i'm getting a steady ~8.48 on
all four lines where i was previously getting a modulating value in the 7VDC range.
anyway, could i have burnt out the L293D chips? they don't seem to be even moderately
warm to the touch anymore. the ardunio itself seems fine, it runs the basic blink code
fine. maybe i should run something more exhaustive?
thanks for any help.
Diagnosing MotorShield Trouble
- adafruit_support_bill
Re: Diagnosing MotorShield Trouble
Reversing polarity can definitely burn out your L293D chips. In most cases the damage is limited to the L293Ds and the shield should operate fine once they are replaced.
thanks. i've ordered some new L293D chips.
