Hi, I have NFC shield, I 'm using it with arduino uno.
I run the readMifare and got this on the serial monitor when I approached the card on the shield.
Have you had this problem before?
NFC Shield- can't read properly
- pUntitled.png (9.22 KiB) Viewed 217 times
- rahatmaini
Re: NFC Shield- can't read properly
You have to set the baud rate in the Serial monitor in the bottom right corner to something like 11500 if I remember correctly, your shield is fine just change the baud rate from 9600 to 11500
ohh thanks it works now..
i tried other bauds before posting here but not that one .. )
