Hi there
i have just purchased your Arduino motor shield and was advised to download the respective library from GIThub.
i did this and extracted the file and saved it in my "libraries" section of my Arduino folder and opened an Arduino sketch.
when i did i received a message saying "The Library "Adafruit-Motor-Shield-Library" cannot be used. Library names must only contain basic letters and numbers.
as a point of reference, i downloaded the "newping" library also today, which installed without issue
please advise if i have done something incorrect.
regards
Martin
motor sheild library
- adafruit_support_bill
Re: motor sheild library
Github likes to put dashes in the repository names. But for some reason the Arduino IDE does not accept dashes.
If you rename the folder - replacing dashes with underscores it will accept it. Be sure to shut down all open IDE windows and re-open after the rename.
http://learn.adafruit.com/adafruit-all- ... nstall-use
thanks for your swift response, it worked a treat
