tft touch screen samples.
rajeetharan
Post by rajeetharan »
dear
im using Adafruit 2.8" TFT Touchscreen.
i need to work with touch screen like user interface ( like an ATM machine interface ).
there is only paint and touch screen projects are there.
where can i find any basic sample codes for this ?
Franklin97355
Re: tft touch screen samples.
Post by Franklin97355 »
Could you be more specific as to what you want the screen to do?
Does the example code show you how to write and read the screen?
rajeetharan
1) i want to run a function when touched in particular rectangle space ( like button press ).
int h1=280;
int w1=40;
int h2=200;
int w2=100;
tft.drawRect(tft.width() -w1 , tft.height() -h1, 40 , 25, RED);
tft.drawRect(tft.width() -w2 , tft.height() -h2, 40 , 30, BLUE);
2) sleep the screen if didnt detect any touch for sime time.
Franklin97355
Here are the library and examples for the touch screen https://github.com/adafruit/Touch-Screen-Library
rajeetharan
dear
honestly i tried that before posting this.
i couldn't find exact one.
which one is used for that purpose ?
Franklin97355
There is probably not one that does exactly what you want. You need to try things out until you understand how they work and then write your own.
dmkmedia
Post by dmkmedia »
did u every get the answer ur looking for as i also need buttons with actions on a touch
