I am not able to compile the ds1307 example sketch (or any other example in the RTCLib).
I have deleted and reinstalled the latest RTCLib from adafruit's download link on the tutorial.
The RTClib should be in the right folder.
Any thoughts? Thanks!
I get the following error messages:
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp: In member function 'uint8_t RTC_DS1307::isrunning()':
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:148: error: 'class TwoWire' has no member named 'write'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:152: error: 'class TwoWire' has no member named 'read'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp: In static member function 'static void RTC_DS1307::adjust(const DateTime&)':
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:158: error: 'class TwoWire' has no member named 'write'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:159: error: 'class TwoWire' has no member named 'write'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:160: error: 'class TwoWire' has no member named 'write'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:161: error: 'class TwoWire' has no member named 'write'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:162: error: 'class TwoWire' has no member named 'write'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:163: error: 'class TwoWire' has no member named 'write'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:164: error: 'class TwoWire' has no member named 'write'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:165: error: 'class TwoWire' has no member named 'write'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:166: error: 'class TwoWire' has no member named 'write'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp: In static member function 'static DateTime RTC_DS1307::now()':
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:172: error: 'class TwoWire' has no member named 'write'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:176: error: 'class TwoWire' has no member named 'read'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:177: error: 'class TwoWire' has no member named 'read'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:178: error: 'class TwoWire' has no member named 'read'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:179: error: 'class TwoWire' has no member named 'read'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:180: error: 'class TwoWire' has no member named 'read'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:181: error: 'class TwoWire' has no member named 'read'
C:\Documents and Settings\Ez\My Documents\Arduino\libraries\RTClib\RTClib.cpp:182: error: 'class TwoWire' has no member named 'read'
RTClib for Datalogger Shield Problem Compiling
- Franklin97355
Re: RTClib for Datalogger Shield Problem Compiling
It looks like it is finding the library but it is either corrupt or the wrong version. Try getting the latest version and reinstalling it.
Thanks for the help; no luck though.
I have tried a variety of RTCLib downloads and the problem continues to be the same.
Maybe it is some problem with TwoWire? How do I fix that?
- Franklin97355
Without your code it will be hard to tell.
- pburgess
What version of the Arduino IDE are you running?
IDE Arduino 1.0.5
I'm running Arduino IDE 1.0, Uno rev 3, and also cannot compile the example from the RTClib, with an error that begins similar to yours; I was hoping someone figured out what was making your problem so it might solve mine too.
My error:
C:\Users\Dan (Admin)\Documents\Arduino\libraries\RTClib\RTClib.cpp: In member function 'uint8_t RTC_DS1307::isrunning()':
C:\Users\Dan (Admin)\Documents\Arduino\libraries\RTClib\RTClib.cpp:148: error: call of overloaded 'write(int)' is ambiguous
C:\Program Files\Arduino\arduino-1.0\libraries\Wire/Wire.h:55: note: candidates are: virtual size_t TwoWire::write(uint8_t)
C:\Program Files\Arduino\arduino-1.0\hardware\arduino\cores\arduino/Print.h:49: note: size_t Print::write(const char*)
C:\Users\Dan (Admin)\Documents\Arduino\libraries\RTClib\RTClib.cpp: In static member function 'static void RTC_DS1307::adjust(const DateTime&)':
C:\Users\Dan (Admin)\Documents\Arduino\libraries\RTClib\RTClib.cpp:158: error: call of overloaded 'write(int)' is ambiguous
C:\Users\Dan (Admin)\Documents\Arduino\libraries\RTClib\RTClib.cpp:166: error: call of overloaded 'write(int)' is ambiguous
C:\Users\Dan (Admin)\Documents\Arduino\libraries\RTClib\RTClib.cpp: In static member function 'static DateTime RTC_DS1307::now()':
C:\Users\Dan (Admin)\Documents\Arduino\libraries\RTClib\RTClib.cpp:172: error: call of overloaded 'write(int)' is ambiguous
My error:
- adafruit_support_bill
Dan, your question is answered in your original thread. http://forums.adafruit.com/viewtopic.php?f=22&t=49979
Please do not double post.
I'm sorry, I was searching the board for any similar problems, and didn't notice that my own post had been answered in the meanwhile!! Thanks!!
