Motor shield V2 with UNO. Speed control and direction
by stevex on Sun Oct 27, 2013 2:42 am
Hello-
I'm a beginner and would like to know how to run 2-4 DC motors with potentiometer speed control and a forward-off-reverse switch for each motor.
thanks for your help.
-steve
stevex
Re: Motor shield V2 with UNO. Speed control and direction
by adafruit_support_rick on Sun Oct 27, 2013 6:03 am
Please have a look at our Motor Shield tutorial to learn how to control motors:
http://learn.adafruit.com/adafruit-moto ... or-arduino
For speed control via a potentiometer, you would connect the pot to an analog input on your Uno. Using the analogRead function, your software will read the pot and then adjust the motor speed accordingly.
by stevex on Wed Oct 30, 2013 2:14 am
I'm still a bit lost. Can someone post some code using a potentiometer for speed control rather than a set speed?
stevex
by adafruit_support_mike on Wed Oct 30, 2013 3:03 am
The function `analogRead()` returns a value between 0 and 1023. The library function `motor->setSpeed()` takes a number between 0 and 255. Putting them together would look something like this:
    potPin = A0;
    motor->setSpeed( analogRead( potPin ) / 4 );
by stevex on Wed Oct 30, 2013 10:56 pm
Thanks. Somehow I got it to work with the below sketch. I still feel like I don't know what I'm doing...just copying an pasting and trying different sketches...
This works tho...
Now I'd like to control direction with a switch (on-off-on). I can do this within the Arduino...? or should I wire this up outside the Arduino?
Probably a dumb question, but this is all new to me....
-steve
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
// Create the motor shield object with the default I2C address
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Select which 'port' M1, M2, M3 or M4. In this case, M1
Adafruit_DCMotor *myMotor = AFMS.getMotor(1);
// You can also make another motor on port M2
//Adafruit_DCMotor *myOtherMotor = AFMS.getMotor(2);
int potPin = A0;
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Adafruit Motorshield v2 - DC Motor test!");
  AFMS.begin();  // create with the default frequency 1.6KHz
  //AFMS.begin(1000);  // OR with a different frequency, say 1KHz
  // Set the speed to start, from 0 (off) to 255 (max speed)
  myMotor->setSpeed(150);
  myMotor->run(FORWARD);
  // turn on motor
  myMotor->run(RELEASE);
  uint8_t i;
  myMotor->setSpeed(analogRead(potPin)/4);
Last edited by adafruit_support_mike on Thu Oct 31, 2013 2:03 am, edited 1 time in total.
Reason: Please use CODE tags when posting code
stevex
by adafruit_support_mike on Thu Oct 31, 2013 2:09 am
Don't worry about copying without truly understanding the code. We all do that when we're learning new tech. The first challenge is getting a system to work in a configuration someone else says /should/ work, then you poke at it to see how it reacts. Eventually things start to look familiar, and you start gaining a deeper understanding of the system.
Copy without shame, make mistakes early and often.. just don't make the same ones over and over again.
To deal with buttons, start with this tutorial to learn how to make buttons work with an Arduino: http://learn.adafruit.com/adafruit-ardu ... s/overview
Once you're comfortable with that, you can generalize the problem of turning an LED on and off to the problem of making a motor go one way or the other.
