I am attempting to use the raspberry pi to control servos with the Motor Shield v2. I have downloaded example code and found the i2c adress with sudo i2c detect, and changed this address to the correct one in the code. When runnning the servo example, however, the servo does not do anything.
I am wondering if this is a power issue? I have power coming to the shield, but was wondering if there needs to be specific power for the servos.
If it is not a power issue, what could it be? Any other possible solutions?
Thanks.
Powering Servos with Motor Shield v2 and Rpi
- adafruit_support_mike
Re: Powering Servos with Motor Shield v2 and Rpi
How are you supplying power to the Motor Shield? The 5v line from a RasPi probably can't supply enough power to make a servo run.
Power is going to the motor shield from the pi at 3.3v for communication with i2c as well as 9v external power from an outlet. Does the optional power for servos need to be connected? Because it is not at this time.
What kind of 9v supply is that and how exactly is it connected to the shield?as well as 9v external power from an outlet.
