Bluefruit EZ-LINK Bluetooth Shield not Connecting
- adafruit_support_rick
Re: Bluefruit EZ-LINK Bluetooth Shield not Connecting
It will normally say "Not connected". You don't need to repair. It will only show "connected" when you actually have an open serial connection to the EZ-Link.
- rbruckel
I can't make a serial connection though because it does not show up in the arduino IDE as a port option.
You're using a Mac? What is the red LED on the EZ-Link shield doing? Is it flashing?
- rbruckel
Yeah it's just flashing red. Even when it pairs and ititially says it's connected the light never changes from blinking red.
It should flash when unconnected, and flash rapidly when connected.
I'm trying to think of a reason why it will pair, but not show up as a port. It definitely shows up in Bluetooth Preferences?
- rbruckel
It only ever flashes slowly, never fast. There are other Bluetooth ports but none with the right description, I believe they're just for other devices I have. I tried them anyway but they didn't work.
Please email [email protected] with a link to this thread for a replacement EZ-Link
- sjoslin7
Hi -
My EZ link pairs with my Mac, but will not complete a successful upload.It worked the first few times I tried with no issue. The AdafruitEZ-link port shows up under Tools > port. I have a 5v Pro Trinket connected to the EZ link.
It looks like it uploads the file, but cannot complete the final verification.
I am powering the Trinket with a portable battery cell through the USB port. Is it possible that the trinket thinks I'm trying to use the USB port for upload?
I was able to upload a very simple sketch that output a line of text and mills() to the Serial Monitor. Nothing beyond that.
Here is the error from the console:
Arduino: 1.6.3 (Mac OS X), Board: "Arduino Uno"
Build options changed, rebuilding all
Sketch uses 2,008 bytes (6%) of program storage space. Maximum is 32,256 bytes.
Global variables use 202 bytes (9%) of dynamic memory, leaving 1,846 bytes for local variables. Maximum is 2,048 bytes.
/Users/steve/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Users/steve/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.AdafruitEZ-Link49fb-SPP -b115200 -D -Uflash:w:/var/folders/nx/h4vg_0m13z1cc_7m4hhp1vh80000gn/T/build2049795512750002989.tmp/trinket-test.cpp.hex:i
avrdude: Version 6.0.1, compiled on Mar 30 2015 at 12:15:29
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Users/steve/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/steve/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.AdafruitEZ-Link49fb-SPP
Using Programmer : arduino
Overriding Baud Rate : 115200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 3
Firmware Version: 5.0
Vtarget : 0.3 V
Varef : 0.3 V
Oscillator : 28.800 kHz
SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.24s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "/var/folders/nx/h4vg_0m13z1cc_7m4hhp1vh80000gn/T/build2049795512750002989.tmp/trinket-test.cpp.hex"
avrdude: writing flash (2008 bytes):
Writing | ################################################## | 100% 8.01s
avrdude: 2008 bytes of flash written
avrdude: verifying flash memory against /var/folders/nx/h4vg_0m13z1cc_7m4hhp1vh80000gn/T/build2049795512750002989.tmp/trinket-test.cpp.hex:
avrdude: load data flash data from input file /var/folders/nx/h4vg_0m13z1cc_7m4hhp1vh80000gn/T/build2049795512750002989.tmp/trinket-test.cpp.hex:
avrdude: input file /var/folders/nx/h4vg_0m13z1cc_7m4hhp1vh80000gn/T/build2049795512750002989.tmp/trinket-test.cpp.hex contains 2008 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 8.00s
avrdude: verifying ...
avrdude: 2008 bytes of flash verified
avrdude: stk500_recv(): programmer is not responding
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
PAGEL : PD7
BS2 : PC2
RETRY pulse : SCK
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Hardware Version: 3
Vtarget : 0.3 V
Varef : 0.3 V
SCK period : 3.3 us
Please post clear, detailed pictures of both sides of the shield, showing your soldering.
- sjoslin7
Here are the photos you requested. My eyesight isn't great, but I'm pretty sure it is clean soldering.
Steve
Steve
- 3.jpg (1018.61 KiB) Viewed 514 times
- 2.jpg (1018.2 KiB) Viewed 514 times
- 1.jpg (874.91 KiB) Viewed 514 times
Looks good.
What's odd is that it appears to have verified the upload before it fails. Does the sketch actually run?
- sjoslin7
Looks like it does run. It wasn't running yesterday, though it may have had to do with something else. Should I be concerned about this?
If the sketch is running, I wouldn't worry about it.
