Problem using Adafruit_RGBLCDShield with Arduino Due
by nataku on Sat Feb 15, 2014 6:01 pm
Hi I am having problem compiling my program for Arduino Due when trying to include the Adafruit RGBLCDShield.
I have used this shield in the past with Uno and it works just fine.
This is the error I received.
/Users/adimulawarman/Documents/Arduino/libraries/Adafruit_RGBLCDShield/Adafruit_MCP23017.cpp:15: fatal error: avr/pgmspace.h: No such file or directory
compilation terminated.
I am not sure if the Due is supported so I downloaded the latest Github library files you guys have for this shield, delete the old library and unzipped the library into the user folder. Restart the Arduino IDE and still the same error. This error is the same when I am running the examples included in the library.
When I changed the board to Uno type, then the error is not there and everything compiled fine.
Is there anything that I am missing. I am including my ino file (rename to TXT) so you can see what I am trying to do. Pretty simple at the moment.
MyMoistureSensor_DueVersion_v2.TXT
(3.52 KiB) Downloaded 3 times
nataku
Re: Problem using Adafruit_RGBLCDShield with Arduino Due
by franklin97355 on Sun Feb 16, 2014 1:04 am
From your error I would say not but I'm not the one who knows for sure.
franklin97355
by nataku on Sun Feb 16, 2014 9:17 am
That is what I thought at first but the Github latest comment on the files says support/compatible for Due added. So I thought it should work.
nataku
by nataku on Sun Feb 16, 2014 10:21 am
Problem solved by downloading latest IDE 1.5.5
It may be good to put a note in Github that the library will work with which version of the IDE.
Thanks for all the good works guys.
nataku
by adafruit_support_mike on Sun Feb 16, 2014 6:01 pm
What version of the IDE were you using previously?
by nataku on Mon Feb 17, 2014 9:52 pm
1.5.2
nataku
by adafruit_support_mike on Tue Feb 18, 2014 12:45 am
Hmm..
The 1.5.x series is still experimental, but it is where most of the Due support lives. We generally advise people to stick with the latest stable version (currently 1.0.5), but that isn't always an option for people using the Due. Honestly, Due support is kind of spotty right now, and will probably remain so until the 1.5.x branch becomes stable.
