cc3000 wifi shield port listening not working
by Peter van C on Tue Feb 18, 2014 8:38 pm
Hi adafruit,
With standard buildtest sketch I do het connection with my network but I'm missing something……..
SSID Name : VoGGi
RSSI : 34
Security Mode: 3
Deleting old connection profiles
Attempting to connect to Gastnetwerk van pvc4
Connected!
Request DHCP
IP Addr: 172.16.42.5
Netmask: 255.255.255.0
Gateway: 172.16.42.1
DHCPsrv: 172.16.42.1
DNSserv: 172.16.42.1
http://www.adafruit.com -> 207.58.139.247
Pinging 207.58.139.247...5 replies
Ping successful!
Closing the connection
Peter van C
Re: cc3000 wifi shield port listening not working
by adafruit_support_mike on Tue Feb 18, 2014 11:53 pm
That's the correct output for the buildtest sketch. What problem are you having?
by Peter van C on Wed Feb 26, 2014 7:20 pm
Oke but when I do use thé adafruit webClient I do get this result
Connecting to Gast P....Waiting to connect...Connected!
Request DHCP
IP Addr: 192.168.42.2
Gateway: 192.168.42.1
DHCPsrv: 192.168.42.1
www.adafruit.com ->
I do have to say that I'm using an Apple-extreme coneccted to my cable-modum.
What can be the problem.
Peter van C
by adafruit_support_mike on Fri Feb 28, 2014 1:34 am
According to that output, your CC3000 is making a connection to the wireless router and getting a connection, but the DNS lookup is failing. That probably has more to do with your wireless router than the CC3000 itself.
Check the router's status/settings pane to see how it handles DNS.
by Peter van C on Wed Mar 12, 2014 2:35 pm
Hardware: Arduino-Uno or Arduino-Mega with CC3000
Netwerk: Apple-Extreme router latest version connect Cablemodem.
After reinstall everything I can say that the problem with portforwarding on port 80 is NO PROBLEM at all.
This combination works now fine !
Peter van C
by adafruit_support_mike on Fri Mar 14, 2014 4:44 pm
Great! Glad to hear you have it working. ;-)
