MotorShield breaks Serial communication?
Re: MotorShield breaks Serial communication?
I was using a USB port (=> 500mA).
500mA is plenty for the shield alone. But not so great for powering motors.
Running the shield is going to put a little more noise on the 5v rail. But not nearly as much as you would get with actual motors. There are many reasons why it is better to have a separate supply for the motors.
- mannphde
Hey I have a Problem with my adafruit motor shield V2
with an ulrasonic sensor srf03 my car drives automaticlly.
But now i want to drive my car with my smartphone (bluetooth zs-040).
But the bluetooth singnals (serialRead) are permanently overwritten from the motorshield.
I get the bluetooth signals from my smartphone into int status2 but the signals are fast overwritten by some other signals but there are only the bluetooth modul and the motorshield
In all baudrates are many freaky signals, when the motorshield starts to drive a motor the signal change in an other freaky ascci
Whats the problem here?
Thanks for help!
Thanks for help!
#include <Wire.h>
#include "utility/Adafruit_MS_PWMServoDriver.h"
int trigger = 12;
int echo = 9;
long dauer = 0;
long entfernung = 12;
Adafruit_DCMotor *myMotor1 = AFMS.getMotor(1);
Adafruit_DCMotor *myMotor2 = AFMS.getMotor(2);
void setup()
//Serial.begin(38400);
AFMS.begin(); // create with the default frequency 1.6KHz
// Set the speed to start, from 0 (off) to 255 (max speed)
myMotor1->setSpeed(50);
myMotor1->run(FORWARD);
myMotor1->run(RELEASE);
myMotor2->setSpeed(50);
myMotor2->run(FORWARD);
myMotor2->run(RELEASE);
pinMode (trigger, OUTPUT);
pinMode (echo, INPUT);
int Status2=0;
if(Serial.available()>0)
Status2 = Serial.read();
Serial.println(entfernung); //mesure the distance
digitalWrite(trigger, LOW); //v
delay(5);
digitalWrite(trigger, HIGH);
delay(10);
dauer= pulseIn(echo,HIGH); //^
entfernung= (dauer/2)/29,1; // mesure the distance
if (Status2 =='0')
{ //automatic V
if (entfernung <= 30)
Stopp();
delay(250);
Links();
delay(1000);
Stopp();
delay(250);
else
Vorwarts();
//automatic ^
else
Stopp(); // drive with Smartphone V
while(Status2=='2')
Vorwarts ();
while(Status2=='3')
Ruckwarts ();
while(Status2=='4')
Rechts ();
while(Status2=='5')
Links ();
} //drive with smartphone ^
void Stopp ()
myMotor1->setSpeed(0);
myMotor2->setSpeed(0);
void Links ()
myMotor2->run(BACKWARD);
void Rechts ()
myMotor1->run(BACKWARD);
void Vorwarts ()
myMotor1->setSpeed(150);
myMotor2->setSpeed(150);
void Ruckwarts ()
myMotor1->setSpeed(110);
myMotor2->setSpeed(110);
DC motors generate a lot of brush noise. This can cause all sorts of interference. Many times this noise can be suppressed at the source by adding some capacitors to the motor terminals. See the motor shield FAQ for details. https://learn.adafruit.com/adafruit-mot ... all#faq-17
