Here's what's happening in that example: The first call plays a complete file. The Arduino is completely blocked from doing anything else until the file finishes playing
// Play one file, don't return until complete
musicPlayer.playFullFile("track001.mp3");
When that file finishes, then the sketch starts playing the second file. However, musicPlayer.startPlayingFile returns immediately, allowing the sketch to get out of setup() and get into loop().
// Play another file in the background, REQUIRES interrupts!
musicPlayer.startPlayingFile("track002.mp3");
Loop runs normally, polling the serial monitor for 's' or 'p' characters. This can all happen because there are interrupts happening in the library. At each interrupt, the library sends another chunk of sound data to the VS1053, and reads another chunk of data from the SD.
This will happen many times before the sound is finally complete. Meanwhile, the sketch is free to do other things. It doesnt have to wait for the sound file to finish playing.
