I'm having problems using temboo service with the cc3000. I followed the instructions , inserting my wi-fi information and my temboo account information and I'm getting errors. My code is below, minus the info that should not be published
sketch_apr15a.ino:3:39: error: diego/ardunet/cc3000utils.h: No such file or directory
sketch_apr15a.ino:4:40: error: diego/ardunet/cc3000client.h: No such file or directory
sketch_apr15a.ino:5:36: error: diego/ardunet/http_get.h: No such file or directory
sketch_apr15a.ino:6:33: error: SSID name /mywifidetails.h: No such file or directory
sketch_apr15a.ino:7:39: error: WEP password/mywifidetails.h: No such file or directory
sketch_apr15a.ino:12:40: error: diego/temboochoreos/choreo.h: No such file or directory
sketch_apr15a.ino:13:42: error: diego/temboochoreos/sendmail.h: No such file or directory
sketch_apr15a.ino:15:37: error: my temboo account name /tembooaccount.h: No such file or directory
sketch_apr15a.ino:16:38: error: my temboo application name/tembooaccount.h: No such file or directory
sketch_apr15a.ino:17:61: error: my temboo application key/tembooaccount.h: No such file or directory
sketch_apr15a:20: error: 'Adafruit_CC3000' does not name a type
sketch_apr15a:22: error: 'CC3000Client' does not name a type
sketch_apr15a.ino: In function 'void setup()':
sketch_apr15a:26: error: 'cc3000' was not declared in this scope
sketch_apr15a:26: error: 'WLAN_SSID' was not declared in this scope
sketch_apr15a:26: error: 'WLAN_PASS' was not declared in this scope
sketch_apr15a:26: error: 'WLAN_SECURITY' was not declared in this scope
sketch_apr15a:26: error: 'startConnection' was not declared in this scope
sketch_apr15a.ino: In function 'void loop()':
sketch_apr15a:31: error: 'TembooChoreo' was not declared in this scope
sketch_apr15a:31: error: expected `;' before 'choreo'
sketch_apr15a:32: error: 'choreo' was not declared in this scope
sketch_apr15a:32: error: 'TEMBOO_MYMAIL_CREDENTIAL' was not declared in this scope
sketch_apr15a:32: error: 'sendEmail' was not declared in this scope
I did some of the examples when your install the adafruit_3000 library " Buildtest etc.. I get no errors some I believe its reading the library. And it appears right next to my Motorshield library. I followed the same steps when I installed the motor library. Unless I'm missing something in the code.
Where do you have the libraries installed? If they are not installed in your sketchbook library folder as detailed in the tutorial posted above, they compiler will not find them reliably.
its the Biicode. I'm having trouble using the biicode. The link adafruit posted uses the Biicode not the arduino IDE. I guess its coverts but I'm having trouble downloading their library
This is telling you that it can't find any of these files. There is no file "diego/ardunet/cc3000utils.h" in your Arduino sketchbook libraries directory, for example.
Yes hello. I'm still having trouble with the biicode link sending a email from your CC3000wifi shield. Would it be better if I just get the Ardiuno Yun and just stack the adafruit motorshield on top ? Would that work ? running out of time with my project. Need advice to get it done. Or just have 2 arduinos for 1 pc if stacking is not possible The Yun using the Arduino 1.5.6-r2 BETA IDE and my uno using the 1.0.5-r2 IDE ?
Not sure. The code looks find but when I upload it, nothing. No email. With the link adafruit posted, You are using Biicode which works with the arduino. But you don't communicate with the arduino IDE. You generate the folder with the necessary files and upload the code on the biicode application. Biicode support was very helpful but didn't get it to work yet.
