Hey,
Impossible to get trusted cursor position.
Following code
if (ts.touched()) {
Serial.println("This is printed repeatedly.");
TS_Point p = ts.getPoint();
// p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
// p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
tft.fillRoundRect(25,95,300,300, 2, RED);
delay(50);
tft.setCursor(30,100);
tft.print(String(p.x)+ ":" + String(p.y) + ":p:" + String(p.z)); //tft.print();
delay(100);
See the results at the video I uploaded: http://youtu.be/8dBUSFnw594
TFT 2.8 Not retrieving current X,Y,Z position
Re: TFT 2.8 Not retrieving current X,Y,Z position
Your code has the map() statements commented out. What happens if you uncomment them?
Hei, the comment are inf¡different , as you can see in the video
If i use the map, then the same effect, well with mapped values to 320x240, but same results.
This code is best but same unreliabl results,
Aparently the problem is at follow:
If i press only 1 time then ok, results are fine, but,
if i press the finger lets say during 2 seconds ( i get e.g,. coords, 50,50), then move my finger to other position then i get old results (50,50), and i must wait 2 or 3 seconds for get new coords (e.g. 120,150)
Solution ?
if (!ts.bufferEmpty()) {
if (ts.touched()) {
tft.fillRoundRect(50,195,tft.width() - 50, tft.height() - 195, 2, BLACK);
delay(50);
tft.setCursor(60,200);
tft.setTextSize(2);
tft.setTextWrap(false);
tft.print(String(p.x) + ":" + String(p.y));
Solution ?
if (ts.touched()) {
delay(50);
tft.setTextSize(2);
The STMPE buffers all reads in a FIFO (this is a benefit, so you can catch touches if they happened between queries), however, that means you have to read thru the entire buffer to get the latest data. bufferSize() will let you know how many points are stored
- aerouta
How do you read the last point in the buffer. I have seen a few questions on this but no clear answer.
This should work:
TSPoint p;
while ( ! ts.bufferEmpty() ) {
p = ts.getPoint();
