I have the ultimate gps logger shield https://www.adafruit.com/products/1272 and i also have the barometric sensor BMP085 also from adafruit.
So the problem i am facing is that i can't get the sd card attached the gps logger shield to get data from both the gps and the barometric sensor at the same time .
I can get it to work only with the gps , and for the barometric sensor i attach an sd card to an ethernet shield and it works , but both separately.
Whenever i try to do both the program freezes and won't let the sd card initalization begin
here is my code
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include <avr/sleep.h>
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
SoftwareSerial mySerial(8,7);
Adafruit_GPS GPS(&mySerial);
// If using hardware serial (e.g. Arduino Mega), comment
// out the above six lines and enable this line instead:
//Adafruit_GPS GPS(&Serial1);
// Set GPSECHO to 'false' to turn off echoing the GPS data to the Serial console
// Set to 'true' if you want to debug and listen to the raw GPS sentences.
#define GPSECHO false
#define chipSelect 10
#define ledPin 13
File logfile;
// this keeps track of whether we're using the interrupt
// off by default!
boolean usingInterrupt = false;
void useInterrupt(boolean); // Func prototype keeps Arduino 0023 happy
long startTime;
int cutterPin = 9;
boolean flag = false;
void setup()
startTime= millis();
// connect at 115200 so we can read the GPS fast enough and echo without dropping chars
// also spit it out
Serial.begin(115200);
// pinMode(cutterPin,OUTPUT);
Serial.println("Adafruit GPS library basic test!");
// 9600 NMEA is the default baud rate for Adafruit MTK GPS's- some use 4800
GPS.begin(9600);
pinMode(ledPin, OUTPUT);
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
if (!SD.begin(chipSelect))
Serial.println("Card init. failed!");
while(1);
logfile = SD.open("sen.txt", FILE_WRITE);
if(!bmp.begin())
/* There was a problem detecting the BMP085 ... check your connections */
Serial.print("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!");
while(1);
// uncomment this line to turn on RMC (recommended minimum) and GGA (fix data) including altitude
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
// uncomment this line to turn on only the "minimum recommended" data
//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCONLY);
// For parsing data, we don't suggest using anything but either RMC only or RMC+GGA since
// the parser doesn't care about other sentences at this time
// Set the update rate
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ); // 1 Hz update rate
// For the parsing code to work nicely and have time to sort thru the data, and
// print it out we don't suggest using anything higher than 1 Hz
// Request updates on antenna status, comment out to keep quiet
GPS.sendCommand(PGCMD_ANTENNA);
// the nice thing about this code is you can have a timer0 interrupt go off
// every 1 millisecond, and read data from the GPS for you. that makes the
// loop code a heck of a lot easier!
useInterrupt(true);
delay(1000);
// Ask for firmware version
mySerial.println(PMTK_Q_RELEASE);
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
char c = GPS.read();
// if you want to debug, this is a good time to do it!
#ifdef UDR0
if (GPSECHO)
if (c) UDR0 = c;
// writing direct to UDR0 is much much faster than Serial.print
// but only one character can be written at a time.
#endif
void useInterrupt(boolean v) {
if (v) {
// Timer0 is already used for millis() - we'll just interrupt somewhere
// in the middle and call the "Compare A" function above
OCR0A = 0xAF;
TIMSK0 |= _BV(OCIE0A);
usingInterrupt = true;
} else {
// do not call the interrupt function COMPA anymore
TIMSK0 &= ~_BV(OCIE0A);
uint32_t timer = millis();
void loop() // run over and over again
if(millis()-startTime > 300000 && flag == false)
cutter();
flag = true;
// in case you are not using the interrupt above, you'll
// need to 'hand query' the GPS, not suggested :(
if (! usingInterrupt) {
// read data from the GPS in the 'main loop'
if (GPSECHO)
if (c) Serial.print(c);
// if a sentence is received, we can check the checksum, parse it...
if (GPS.newNMEAreceived()) {
// a tricky thing here is if we print the NMEA sentence, or data
// we end up not listening and catching other sentences!
// so be very wary if using OUTPUT_ALLDATA and trytng to print out data
//Serial.println(GPS.lastNMEA()); // this also sets the newNMEAreceived() flag to false
if (!GPS.parse(GPS.lastNMEA())) // this also sets the newNMEAreceived() flag to false
return; // we can fail to parse a sentence in which case we should just wait for another
// if millis() or timer wraps around, we'll just reset it
if (timer > millis()) timer = millis();
// approximately every 2 seconds or so, print out the current stats
if (millis() - timer > 2000) {
Serial.println("hello");
timer = millis(); // reset the timer
gps();
void gps()
if(logfile.print("\nTime: "))
Serial.println("yes");
logfile.flush();
logfile.print(GPS.hour, DEC); logfile.print(':');
logfile.print(GPS.minute, DEC); logfile.print(':');
logfile.print(GPS.seconds, DEC); logfile.print('.');
logfile.println(GPS.milliseconds);
logfile.print("Date: ");
logfile.print(GPS.day, DEC); logfile.print('/');
logfile.print(GPS.month, DEC); logfile.print("/20");
logfile.println(GPS.year, DEC);
logfile.print("Fix: "); logfile.print((int)GPS.fix);
logfile.print(" quality: "); logfile.println((int)GPS.fixquality);
if (GPS.fix)
Serial.println("we have a fix");
logfile.print("Location: ");
logfile.print(GPS.latitude, 4); logfile.print(GPS.lat);
logfile.print(", ");
logfile.print(GPS.longitude, 4); logfile.println(GPS.lon);
logfile.print("Speed (knots): "); logfile.println(GPS.speed);
logfile.print("Angle: "); logfile.println(GPS.angle,4);
float altitude = GPS.altitude;
/* if(int(altitude) > 2000 && flag == false)
cutter();
flag = true;
logfile.print("Altitude: "); logfile.println(GPS.altitude,4);
logfile.print("Satellites: "); logfile.println((int)GPS.satellites);
void bar()
void cutter()
Serial.println("cut");
digitalWrite(cutterPin,HIGH);
delay(120000);
digitalWrite(cutterPin,LOW);
