Is it possible to reduce power to the stepper motors? I could do this with the Accelstepper
such as:
// Set power on pins D3 and D11, the ENABLE1 and ENABLE2 pins. The parameter
// is in the range 0 (no power) to 255 (maximum power).
analogWrite(3, 70);
analogWrite(11, 70);
how do you do this with I2C?
Motor Sheild V2
Re: Motor Sheild V2
Not really.. microstepping requires PWM'd output to both coils, and reducing the overall power would do wierd things to the step resolution.
- adafruit_support_bill
Re: Motor Sheild V2
If you just want to reduce the holding torque current, you can hack the library as in this thread: http://forums.adafruit.com/viewtopic.ph ... 6&p=273584
Re: Motor Sheild V2
It worked for the stepper motor hooked up m3 m4, but did not seem to effect the other stepper motor on m1 m2. Could you help?
- cryptogoth
Re: Motor Sheild V2
I reversed the power supply to my v2 shield and one of the driver chips let out its magic smoke and has a burn blister on it now and smells funny.
Is there a schematic available for this board? Is there a way to replace this chip to fix the board? What else could have been damaged by such a power reversal?
Thanks,
Paul
Thanks,
Paul
Re: Motor Sheild V2
// Shows how to run three Steppers at once with varying speeds
// Requires the Adafruit_Motorshield v2 library
// https://github.com/adafruit/Adafruit_Motor_Shield_V2_Library
// And AccelStepper with AFMotor support
// This tutorial is for Adafruit Motorshield v2 only!
// Will not work with v1 shields
#include <AccelStepper.h>
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
//Adafruit_MotorShield AFMSbot(0x61); // Rightmost jumper closed
Adafruit_MotorShield AFMStop(0x60); // Default address, no jumpers
// Connect two steppers with 200 steps per revolution (1.8 degree)
// to the top shield
Adafruit_StepperMotor *myStepper1 = AFMStop.getStepper(200, 1);
Adafruit_StepperMotor *myStepper2 = AFMStop.getStepper(200, 2);
// reduce power
// Connect one stepper with 200 steps per revolution (1.8 degree)
// to the bottom shield
//Adafruit_StepperMotor *myStepper3 = AFMSbot.getStepper(200, 2);
// you can change these to DOUBLE or INTERLEAVE or MICROSTEP!
// wrappers for the first motor!
void forwardstep1() {
myStepper1->onestep(FORWARD, SINGLE);
void backwardstep1() {
myStepper1->onestep(BACKWARD, SINGLE);
// wrappers for the second motor!
void forwardstep2() {
myStepper2->onestep(FORWARD, DOUBLE);
void backwardstep2() {
myStepper2->onestep(BACKWARD, DOUBLE);
// wrappers for the third motor!
//void forwardstep3() {
// myStepper3->onestep(FORWARD, INTERLEAVE);
//void backwardstep3() {
// myStepper3->onestep(BACKWARD, INTERLEAVE);
// Now we'll wrap the 3 steppers in an AccelStepper object
AccelStepper stepper1(forwardstep1, backwardstep1);
AccelStepper stepper2(forwardstep2, backwardstep2);
//AccelStepper stepper3(forwardstep3, backwardstep3);
void setup()
//AFMSbot.begin(); // Start the bottom shield
AFMStop.begin(); // Start the top shield
// reduce power
//void begin(uint16_t freq = 1);
//void begin(uint8_t freq = 1);
stepper1.setMaxSpeed(200.0);
stepper1.setAcceleration(100.0);
stepper1.moveTo(700);
stepper2.setMaxSpeed(200.0);
stepper2.setAcceleration(100.0);
stepper2.moveTo(700);
//stepper3.setMaxSpeed(300.0);
//stepper3.setAcceleration(100.0);
//stepper3.moveTo(1000000);
void loop()
// Change direction at the limits
if (stepper1.distanceToGo() == 0)
stepper1.moveTo(-stepper1.currentPosition());
if (stepper2.distanceToGo() == 0)
stepper2.moveTo(-stepper2.currentPosition());
// if (stepper3.distanceToGo() == 0)
// stepper3.moveTo(-stepper3.currentPosition());
stepper1.run();
stepper2.run();
myStepper1->hold(0); // specify holding current value from 0-255
myStepper2->hold(0); // specify holding current value from 0-255
//stepper3.run();
This is the library for the Adafruit Motor Shield V2 for Arduino.
It supports DC motors & Stepper motors with microstepping as well
as stacking-support. It is *not* compatible with the V1 library!
It will only work with https://www.adafruit.com/products/1483
Adafruit invests time and resources providing this open
source code, please support Adafruit and open-source hardware
by purchasing products from Adafruit!
BSD license, check license.txt for more information.
All text above must be included in any redistribution.
#ifndef _Adafruit_MotorShield_h_
#define _Adafruit_MotorShield_h_
#include <inttypes.h>
#include <Wire.h>
//#define MOTORDEBUG
#define MICROSTEPS 16 // 8 or 16
#define MOTOR1_A 2
#define MOTOR1_B 3
#define MOTOR2_A 1
#define MOTOR2_B 4
#define MOTOR4_A 0
#define MOTOR4_B 6
#define MOTOR3_A 5
#define MOTOR3_B 7
#define FORWARD 1
#define BACKWARD 2
#define BRAKE 3
#define RELEASE 4
#define SINGLE 1
#define DOUBLE 2
#define INTERLEAVE 3
#define MICROSTEP 4
class Adafruit_MotorShield;
class Adafruit_DCMotor
public:
Adafruit_DCMotor(void);
friend class Adafruit_MotorShield;
void run(uint8_t);
void setSpeed(uint8_t);
private:
uint8_t PWMpin, IN1pin, IN2pin;
Adafruit_MotorShield *MC;
uint8_t motornum;
class Adafruit_StepperMotor {
public:
Adafruit_StepperMotor(void);
void step(uint16_t steps, uint8_t dir, uint8_t style = SINGLE);
void setSpeed(uint16_t);
uint8_t onestep(uint8_t dir, uint8_t style);
void release(void);
void hold(uint8_t holdingCurrent);
uint32_t usperstep, steppingcounter;
private:
uint8_t PWMApin, AIN1pin, AIN2pin;
uint8_t PWMBpin, BIN1pin, BIN2pin;
uint16_t revsteps; // # steps per revolution
uint8_t currentstep;
uint8_t steppernum;
public:
Adafruit_MotorShield(uint8_t addr = 0x60);
friend class Adafruit_DCMotor;
void begin(uint16_t freq = 1600);
void setPWM(uint8_t pin, uint16_t val);
void setPin(uint8_t pin, boolean val);
Adafruit_DCMotor *getMotor(uint8_t n);
Adafruit_StepperMotor *getStepper(uint16_t steps, uint8_t n);
private:
uint8_t _addr;
uint16_t _freq;
Adafruit_DCMotor dcmotors[4];
Adafruit_StepperMotor steppers[2];
Adafruit_PWMServoDriver _pwm;
#endif
#if (ARDUINO >= 100)
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include <Wire.h>
#include "Adafruit_MotorShield.h"
#include <Adafruit_PWMServoDriver.h>
#ifdef __AVR__
#define WIRE Wire
#else // Arduino Due
#define WIRE Wire1
#endif
#if (MICROSTEPS == 8)
uint8_t microstepcurve[] = {0, 50, 98, 142, 180, 212, 236, 250, 255};
#elif (MICROSTEPS == 16)
uint8_t microstepcurve[] = {0, 25, 50, 74, 98, 120, 141, 162, 180, 197, 212, 225, 236, 244, 250, 253, 255};
#endif
Adafruit_MotorShield::Adafruit_MotorShield(uint8_t addr) {
_addr = addr;
_pwm = Adafruit_PWMServoDriver(_addr);
void Adafruit_MotorShield::begin(uint16_t freq) {
// init PWM w/_freq
WIRE.begin();
_pwm.begin();
_freq = freq;
_pwm.setPWMFreq(_freq); // This is the maximum PWM frequency
for (uint8_t i=0; i<16; i++)
_pwm.setPWM(i, 0, 0);
void Adafruit_MotorShield::setPWM(uint8_t pin, uint16_t value) {
if (value > 4095) {
_pwm.setPWM(pin, 4096, 0);
} else
_pwm.setPWM(pin, 0, value);
void Adafruit_MotorShield::setPin(uint8_t pin, boolean value) {
if (value == LOW)
_pwm.setPWM(pin, 0, 0);
else
Adafruit_DCMotor *Adafruit_MotorShield::getMotor(uint8_t num) {
if (num > 4) return NULL;
num--;
if (dcmotors[num].motornum == 0) {
// not init'd yet!
dcmotors[num].motornum = num;
dcmotors[num].MC = this;
uint8_t pwm, in1, in2;
if (num == 0) {
pwm = 8; in2 = 9; in1 = 10;
} else if (num == 1) {
pwm = 13; in2 = 12; in1 = 11;
} else if (num == 2) {
pwm = 2; in2 = 3; in1 = 4;
} else if (num == 3) {
pwm = 7; in2 = 6; in1 = 5;
dcmotors[num].PWMpin = pwm;
dcmotors[num].IN1pin = in1;
dcmotors[num].IN2pin = in2;
return &dcmotors[num];
Adafruit_StepperMotor *Adafruit_MotorShield::getStepper(uint16_t steps, uint8_t num) {
if (num > 2) return NULL;
num--;
if (steppers[num].steppernum == 0) {
// not init'd yet!
steppers[num].steppernum = num;
steppers[num].revsteps = steps;
steppers[num].MC = this;
uint8_t pwma, pwmb, ain1, ain2, bin1, bin2;
if (num == 0) {
pwma = 8; ain2 = 9; ain1 = 10;
pwmb = 13; bin2 = 12; bin1 = 11;
pwma = 2; ain2 = 3; ain1 = 4;
pwmb = 7; bin2 = 6; bin1 = 5;
steppers[num].PWMApin = pwma;
steppers[num].PWMBpin = pwmb;
steppers[num].AIN1pin = ain1;
steppers[num].AIN2pin = ain2;
steppers[num].BIN1pin = bin1;
steppers[num].BIN2pin = bin2;
return &steppers[num];
MOTORS
Adafruit_DCMotor::Adafruit_DCMotor(void) {
MC = NULL;
motornum = 0;
PWMpin = IN1pin = IN2pin = 0;
void Adafruit_DCMotor::run(uint8_t cmd) {
switch (cmd) {
case FORWARD:
MC->setPin(IN2pin, LOW); // take low first to avoid 'break'
MC->setPin(IN1pin, HIGH);
break;
case BACKWARD:
MC->setPin(IN1pin, LOW); // take low first to avoid 'break'
MC->setPin(IN2pin, HIGH);
break;
case RELEASE:
break;
void Adafruit_DCMotor::setSpeed(uint8_t speed) {
MC->setPWM(PWMpin, speed*16);
STEPPERS
Adafruit_StepperMotor::Adafruit_StepperMotor(void) {
revsteps = steppernum = currentstep = 0;
uint16_t steps, Adafruit_MotorShield controller) {
revsteps = steps;
steppernum = 1;
currentstep = 0;
if (steppernum == 1) {
latch_state &= ~_BV(MOTOR1_A) & ~_BV(MOTOR1_B) &
~_BV(MOTOR2_A) & ~_BV(MOTOR2_B); // all motor pins to 0
// enable both H bridges
pinMode(11, OUTPUT);
pinMode(3, OUTPUT);
digitalWrite(11, HIGH);
digitalWrite(3, HIGH);
// use PWM for microstepping support
MC->setPWM(1, 255);
MC->setPWM(2, 255);
} else if (steppernum == 2) {
latch_state &= ~_BV(MOTOR3_A) & ~_BV(MOTOR3_B) &
~_BV(MOTOR4_A) & ~_BV(MOTOR4_B); // all motor pins to 0
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
digitalWrite(5, HIGH);
digitalWrite(6, HIGH);
MC->setPWM(3, 255);
MC->setPWM(4, 255);
void Adafruit_StepperMotor::setSpeed(uint16_t rpm) {
//Serial.println("steps per rev: "); Serial.println(revsteps);
//Serial.println("RPM: "); Serial.println(rpm);
usperstep = 60000000 / ((uint32_t)revsteps * (uint32_t)rpm);
steppingcounter = 0;
void Adafruit_StepperMotor::release(void) {
MC->setPin(AIN1pin, LOW);
MC->setPin(AIN2pin, LOW);
MC->setPin(BIN1pin, LOW);
MC->setPin(BIN2pin, LOW);
MC->setPWM(PWMApin, 0);
MC->setPWM(PWMBpin, 0);
void Adafruit_StepperMotor::step(uint16_t steps, uint8_t dir, uint8_t style) {
uint32_t uspers = usperstep;
uint8_t ret = 0;
if (style == INTERLEAVE) {
uspers /= 2;
else if (style == MICROSTEP) {
uspers /= MICROSTEPS;
steps *= MICROSTEPS;
#ifdef MOTORDEBUG
Serial.print("steps = "); Serial.println(steps, DEC);
#endif
while (steps--) {
//Serial.println("step!"); Serial.println(uspers);
ret = onestep(dir, style);
delay(uspers/1000); // in ms
steppingcounter += (uspers % 1000);
if (steppingcounter >= 1000) {
delay(1);
steppingcounter -= 1000;
while ((ret != 0) && (ret != MICROSTEPS)) {
delay(1);
uint8_t Adafruit_StepperMotor::onestep(uint8_t dir, uint8_t style) {
uint8_t a, b, c, d;
uint8_t ocrb, ocra;
ocra = ocrb = 255;
// next determine what sort of stepping procedure we're up to
if (style == SINGLE) {
if ((currentstep/(MICROSTEPS/2)) % 2) { // we're at an odd step, weird
if (dir == FORWARD) {
currentstep += MICROSTEPS/2;
else {
currentstep -= MICROSTEPS/2;
} else { // go to the next even step
currentstep += MICROSTEPS;
else {
currentstep -= MICROSTEPS;
} else if (style == DOUBLE) {
if (! (currentstep/(MICROSTEPS/2) % 2)) { // we're at an even step, weird
} else {
} else { // go to the next odd step
} else {
} else if (style == INTERLEAVE) {
} else {
currentstep++;
} else {
// BACKWARDS
currentstep--;
currentstep += MICROSTEPS*4;
currentstep %= MICROSTEPS*4;
ocra = ocrb = 0;
if ( (currentstep >= 0) && (currentstep < MICROSTEPS)) {
ocra = microstepcurve[MICROSTEPS - currentstep];
ocrb = microstepcurve[currentstep];
} else if ( (currentstep >= MICROSTEPS) && (currentstep < MICROSTEPS*2)) {
ocra = microstepcurve[currentstep - MICROSTEPS];
ocrb = microstepcurve[MICROSTEPS*2 - currentstep];
} else if ( (currentstep >= MICROSTEPS*2) && (currentstep < MICROSTEPS*3)) {
ocra = microstepcurve[MICROSTEPS*3 - currentstep];
ocrb = microstepcurve[currentstep - MICROSTEPS*2];
} else if ( (currentstep >= MICROSTEPS*3) && (currentstep < MICROSTEPS*4)) {
ocra = microstepcurve[currentstep - MICROSTEPS*3];
ocrb = microstepcurve[MICROSTEPS*4 - currentstep];
#ifdef MOTORDEBUG
Serial.print("current step: "); Serial.println(currentstep, DEC);
Serial.print(" pwmA = "); Serial.print(ocra, DEC);
Serial.print(" pwmB = "); Serial.println(ocrb, DEC);
#endif
MC->setPWM(PWMApin, ocra*16);
MC->setPWM(PWMBpin, ocrb*16);
// release all
uint8_t latch_state = 0; // all motor pins to 0
//Serial.println(step, DEC);
if ((currentstep >= 0) && (currentstep < MICROSTEPS))
latch_state |= 0x03;
if ((currentstep >= MICROSTEPS) && (currentstep < MICROSTEPS*2))
latch_state |= 0x06;
if ((currentstep >= MICROSTEPS*2) && (currentstep < MICROSTEPS*3))
latch_state |= 0x0C;
if ((currentstep >= MICROSTEPS*3) && (currentstep < MICROSTEPS*4))
latch_state |= 0x09;
} else {
switch (currentstep/(MICROSTEPS/2)) {
case 0:
latch_state |= 0x1; // energize coil 1 only
break;
case 1:
latch_state |= 0x3; // energize coil 1+2
break;
case 2:
latch_state |= 0x2; // energize coil 2 only
break;
case 3:
latch_state |= 0x6; // energize coil 2+3
break;
case 4:
latch_state |= 0x4; // energize coil 3 only
break;
case 5:
latch_state |= 0xC; // energize coil 3+4
break;
case 6:
latch_state |= 0x8; // energize coil 4 only
break;
case 7:
latch_state |= 0x9; // energize coil 1+4
break;
#ifdef MOTORDEBUG
Serial.print("Latch: 0x"); Serial.println(latch_state, HEX);
#endif
if (latch_state & 0x1) {
// Serial.println(AIN2pin);
MC->setPin(AIN2pin, HIGH);
} else {
if (latch_state & 0x2) {
MC->setPin(BIN1pin, HIGH);
// Serial.println(BIN1pin);
} else {
if (latch_state & 0x4) {
MC->setPin(AIN1pin, HIGH);
// Serial.println(AIN1pin);
} else {
if (latch_state & 0x8) {
MC->setPin(BIN2pin, HIGH);
// Serial.println(BIN2pin);
} else {
return currentstep;
void Adafruit_StepperMotor::hold(uint8_t holdingCurrent)
MC->setPWM(PWMApin, holdingCurrent);
MC->setPWM(PWMBpin, holdingCurrent);
Re: Motor Sheild V2
Not sure why it would not work on M3-M4.
To set the holding current to 0, you can just call release().
myStepper1->release();
myStepper2->release();
Re: Motor Sheild V2
It was the m1 m2 stepper that didn't seem to work with this hack
Re: Motor Sheild V2
Either way. I don't see why it would work for one and not the other. Have you tried release?
Re: Motor Sheild V2
Thanks, I did a little more testing and it is making a difference. I thrown off because the one drive chip wasn't that before. Now the one that was getting really hot is running really cool.
- ajacob4
Re: Motor Sheild V2
Hi i just recently purchased a adafuit motor shield v2.3. I attached it with my arduino uno and hooked it up to a dc power supply. When I went to turn on the dc power supply the output was set a 30 volts and as a result my shield began to smoke up. I am wondering if need to replace the entire thing or if it is still salvageable, PLEASE HELP ITS FOR A RESEARCH PROJECT
THANKS
THANKS
Re: Motor Sheild V2
If you are good at surface mount soldering, you could probably replace the damaged chips. The chips subject to damage from the overvoltage would be the two TB6612 bridge chips and the reverse-voltage protection MOSFET. Did the smoke come from any particular location on the board?
